Been wrenching on cruisers for decades, done a few builds, don’t post much as my opinion and work isn’t in same league with our experts. But I do consider myself almost competent, as I do all possible work myself.
But, felt I should fess up a couple of mistakes.
Latest -carefully Rebuilt a 81 2F for a 45 project, but no power on hills, vacuum at 15, 2ndary wouldn’t open. Spent Over a week, 3 different carbs, messed with timing, dizzy, removed manifolds looking for leaks,finally drove it 40 miles (in disgust), was running worse on return, pulled plugs and found 5 & 6 spotless, others fouled. Wait a minute....then, finally discover plug wires 5 & 6 were reversed.
Have always put the dogleg plug boot on 6, unfortunately it went to #5 on the cap.
1/3 more power now.
Perhaps a worse mistake, my 45 project from a decade ago also always seemed to have less power than my ragtop. Went thru lots of threads, learned to live with it.
But a few weeks ago, doing throttle linkage setup for the new 45, caused me to go over the same on the old one.
Found that if I raised the vertical throttle rod, rotating the torque rod, full throttle was achieved. But if I put a brick shaped rock on the pedal, to the floor, torque rod only rotated 80% of the way. Had not been achieving full throttle.
Pedal flex? Worn ball joint?
Lengthened the rod now it has 25% more power. Drove it this way 10 years
I feel better now getting this off my chest
1/3 more power now.
and was like oh hears the problem. i love her so much
