Confessions- embarrassing errors
I helped a buddy swap a bmw clutch that he said was slipping. When we pulled the clutch, the disc didnt look too bad, but he said it was slipping so we put the new one in. Still slipped. Turns out the BMW had a dual mass flywheel and they can mimic a slipping clutch when they go bad. My first experience with a dual mass flywheel failure. I should have known when the disc looked good.
30 or so years ago I was messing with the steering and I had taken off the main steering arm...pitman arm I guess it is, the one that connects to the steering box. I guess I did some hammering on it at some point and screwed the threads all up so that I could not get that huge nut back on, the one that secures the pitman arm and thus all the steering. No problem, I thought, I'll just stick these vice grips on there reeeeeeal tight. So I drove it like that for years. The truck then sat for close to two decades and I only got it up and running again about 3 years ago. Well, in doing so I noticed my vice grip bandaid. The vice grips were completely distorted and torqued and just about a hairs breadth from popping completely off, along with the pitman arm, no doubt....WOW!!! I was one lucky, stupid sonabitch!
I was able to cut off just the very tip of the threaded shaft, the damaged part, and get the bolt back on (which somehow I still had) nice and snug. Alls well that ends well I guess but kids, don't try this at home.
How did Darwin avoid you ?
A lot of the errors we make are the result of a previous action like :
1st marriage
and
owning British cars
and
buying more British cars
and then
buying a British motorcycle.
Guilty
You means, ... like with a positive ground? That takes me back about 43 years!
I won't fess up to anything else since then!
I was helping a VERY non-mechanically inclined buddy replace valve cover gaskets on his Subaru. I read the manual and then set my ft-lbs torque wrench to something like 45ftlbs. He climbed under the car and proceeded to “tighten” all the cover bolts he could reach, which was over half.
He handed me the wrench and I promptly stripped the first bolt... I asked him if he got his tight and he said “I think so”. Ugh. I crawled under the car and realized he had stripped every single bolt and was completely ignorant as he did it.
The damn manual was in IN/LBS not ft-lbs... I felt so bad that I paid the $800 repair bill. I don’t wrench on friends cars anymore...
my first fj40 was a 12/78 when i was age 16 in 1990 ,
I had the Land Cruiser Addiction bad , REAL Bad ... even in my first year with a drivers license in hand .
I wanted bigger tires Bad Too , Like 33x12.50R15 BFG mud terrains
( back when the tread design pattern was still simple & kool at the same time )
So I dreamed up a bright idea of how to squeeze bigger tires under the rear wheel wells without cutting them , Move the Rear
AXLE back on the leaf springs , I jacked up the frame on blocks , and un-did the U bolts , I removed the center pins and
proceeded to drill 2 new center pin holes 2" inches back from the original ones .
I did not know at the time what spring'd steel was nor how many trips to Sears Craftsman Tools Dept At the mall my mom & dad
would have to make for drill bits , keep in mind there was No dremmle tool back then , or at least none known to me ?
I finally got the holes drilled and re-positioned the axle back in place ( 2" inches further back on the leafs ) & took my girl out
for friday Night Cruising . after a hour or two there was a loud Bang ! :eek:
The drive shaft had Blown Up on 2 pieces shattered .
i found out later this is because i extended the telescope distance by 2" inches as well :confused:
I Then had to put the axle back its original place while the drive shaft was at the driveshaft shop getting rebuilt .
I then discovered a crack in one of the top leafs due to all my extra center pin holes !
Needless to say my parents were Pis#ed Off Royally and i had to ride the Cheeze-Box to high school for at least a month after ........:ninja:
Noticed my dash light coming on when braking. Figured I had a short/wires stripped and rubbing after putting my frame off resto back together. Searched all over, disassembled taillights, and couldn't find the culprit.
Tried taking out the bulb and realized I had a single contact bulb instead of a double contact bulb in the middle socket.
Spent about 2 hours to figure out that I don't know how to install a light bulb. Seems like there is a joke in there somewhere...
This thread needs to be pinned - a little levity = sanity. I'll get this back in the day tale off my chest ....
I've just moved into a new tri-plex that happened to have three garages adjacent to each other (i.e. three single car garages all next to each other). I meet my neighbors and they are hard core car and moto guys, wrenching regularly on stuff out of my comfort zone.
Saturday morning and I'm going to change the oil in my 240z. Out for a cruise to warm it up, pull back in, back end out to give myself a little room in the front. Jack it up, jackstands in place, drain pan in place, wrenches, filter wrench, checks all around.
Turn off the drain plug, oil drains. Off comes the oil filter, etc ... you all know the routine. Now ... if you've ever changed the oil filter on a 240z, you know it's hard to get to.
Get it all done, run the engine for 30 seconds, off, check fluid levels, top off, good to go. Clean up and get ready for a nice Saturday cruise.
Hop back in, fire up the car and back on out ... only to see a verrrry obvious trail of fluid trailing the front end of my car, all the way onto the street. Moment of huge panic ... I'm on street about 20 feet from my garage. Clearly something's gone very wrong. Being a novice+ mechanical guy, I have no ideas on what this is and my mind is racing. Do I cut the engine and strand myself in the street? Split-second decision I pull back into the garage and turn off the car. What do I do next? Do I pop the hood and begin diagnosis of the problem? Nope. I grab as many rags and paper towels as I can find and I SCRAMBLE onto the driveway and street to try and clean up the evidence of my embarrassing error (aka epic fail). Am I doing this out of care for the environment or cleanliness? Nope. Pure embarrassment. Rubber-necking around as I wipe and wipe and wipe. Is anybody up yet .. who is seeing me with my failure on full display?!
Nothing related comes up with neighbors for at least a month (I'm sure not going to bring it up - maybe they never noticed!). Thankfully it rains a week later. Finally two months later after earning a little more cred with the neighbors I bring up my fail - they never saw it happen but were wondering what the light stains were.
What happened? This knucklehead forgot the most basic checklist item - did the washer from the old oil filter come off with the filter; it didn't - and new filter washer was sandwiched against old filter washer, all creating a strong enough seal to withstand my 30 second run at low RPM. Not the pull out of the driveway. No damage.
I was trying to pump oil into the gearbox of my cruiser from a 3L fruit juice bottle by pumping compressed air in to the bottle, i didn't bother putting a valve or something in the air line to regulate the pressure, it worked mint for the first 10 seconds, i was watching the oil flow through the hose then the bottle exploded right in front of my face. Wasted about 2 liters, happened 4 years ago that shirt still smells like gearbox oil.
Not enough space for all of mine, but one floats to the top. My first FJ40 was a rolling parts bin. I was finally to the point of a test fire and was screwing around with the distributor and a remote starter to find TDC......left it in gear..... ran over my self, well my right foot.
The foot was fine, but my cat like reflexes caused me to pull back hard right when I felt the weight and tore a meniscus. No real lasting physical scars, but lots of mental damage every time I see that little red trigger .....
This reminded me of something I had forgotten about...
My first fj40...never idled right even after trying my best (in hindsight was pitiful) so I did what was smart, pulled the oem carb and mailed it to JimC. Few months later, it’s back, I install it and while standing alongside the drivers door (not in the truck), fire her up. To my surprise, cranks first time (even after sitting for months) and to my horror, was in first gear. Had to rebuild the stairs from my garage into our house :eek:.
Luckily zero damage to the 40. Learned a couple things that day. 1) JimC is a master of the Toyota carburetor and 2) fj40s do not have a neutral safety switch like my modern day Audi did...allowing the truck to start without the clutch depressed. :rofl:
1st marriage
and
owning British cars
and
and then
Guilty as charged First car a '71 MGB Lot's of fun electrical adventures with Lucas ( Also known as the prince of darkness)
I'm 57 and have been wrenching every vehicle I have owned for over 40 years. Thank goodness as we grow in experience and wisdom the major SNAFU's are all in the distant past.....like three days ago when I was putting new wheel bearings in my wife's Toyota. Removed the retaining clip, then proceeded to install the removal tool and press them THE WRONG DIRECTION. Did I stop and figure it out when things did not budge, or keep pressing until I bent the tool........
glad i’m not alone here. i ordered a set of brake pads to go with brand new rotors. the plastic backing plates were on them so i just inserted them and went to bed the brakes in. they stopped fine but made a lot of grinding noise. first time i’ve ever needed brakes in so never thought twice about the noise. it’ll go away right? well after about 50
i’m of driving it was still making the noise. had another look and two of the four pads were in backwards and my rotors were both shot. so after redoing my brakes again i now have a screwed up rotor hanging on my wall to remind me to double check everything!
Drove 600 miles to do an engine swap at mate's place. Did the swap, plus several upgrades over six long, long days - was supposed to be three. Went to fire it up and it was a dog. No power past idle, wouldn't run right - just an utter POS. Called everyone I knew but no one could help. Tried two carbs, two dizzies, new leads, plugs, oil, fuel, filters - everything. Flew home on the missus dime as I had run out of money and needed to get back to work. Old mate calls me up two weeks later and we were talking s*** about something or other and he has this eureka moment and hangs up. Calls me back 5 mins later from behind the wheel of my 45 to the tune of this sweet, sweet V8 at full noise. He yells over the din: 'Plug leads in the wrong order! She f**ken flies!'
Exhaustion will do that. The truck is still there.
