I'm in the process of replacing the transmission fluid and drained the pan today. The fluid was absolutely black with no evidence it was red before, almost like a year old used engine oil. Also, it had some odd smell, not burnt but if it was not fresh. I guess it was never changed over 16 years even the mileage is just over 78,000 km (The Land Cruiser was imported from Japan earlier this year).
Based on the condition of the old fluid I wanted to do a full replacement. I looked around and could not figure out where outlet and inlet lines go to. This is A750F 5-speed AT found on later models of 100 series and Lexus LX 470 (2003 to 2007 model years) even though it's 200 series. I can see both outlet and inlet hoses going into and out of the thermostat similar to 6-speed AT but there is no shaft where to put a pin to hold it in place, the hoses are going further up to something like a heater T at the very top. There is nothing going into or coming out of the radiator. All I can see are hoses for the power steering. There is some type of a cooler underneath front bumper but I have no idea what is it.
If I try to disconnect the outlet by the AT before the thermostat the hose is too short to remove it. I need help locating a place where to disconnect a hose either outlet or inlet. I did this procedure on my 2008 Toyota 4Runner and 2006 Lexus LX 470 but one had an external AT cooler and another one had an AT hose coming from the radiator.
