Complete PTO Rebuild thread
Advent said:
I'm going to type up all the text from that. I just cropped out all the images and changed them back to white. MUCH better. Just need to get my site's gallery set up so that I can throw them in there easier.
Thanks!
Off subject, but will you put a link up. Interested in seeing your site.
Dave
Of course.
My site's at http://www.cuzzort.net
I haven't had much to put in there yet, so there's not much up. I got kind of fed up with the gallery before and it wasn't a pressing issue at the time. The PTO manual might just be the first real content :)
FYI-
All of the seals and bearings are available from Toyota. (At least when I redid mine). The U joints are available but a little spendy. There are very few "hard parts", as I recall only the engage lever and pins were available. Definitley check with Cdan as he is the man!
As a side note check the drive flanges and if they are scored from the seal you may want to get a speedy sleeve for them rather thatn have an issue later.
Thanks Ground up for the info. Calling Cdan tomorrow to figure out what I can get. I will be rebuilding this as far as possible.
I took this completly apart because a: I am a man and b: This is going in Pacino my nice 45lv Purist resto and It needs to be perfect... so complete inspection of the inside the housing as well as outside needed to be done
:cheers:
Coolerman said:
Pretty cool info Cruiser_nerd. Has anyone actually seen the rear power take off parts available anywhere?
I've got 5 or 6 lo- mileage rear PTOs on the shelf from JDM service vehicles if anybody's interested. Just picked up a gorgeous complete PTO assembly from a 73FJ40 as well that I'm prolly not gonna use.
Never really looked into parts availability for either, but I've had a few customers tell me that only seals, u joints and shear pins were still available.
Hth
Mark A.
Has anyone found a source for the PTO winch bronze gear, the wearing gear that's driven by the worm, the larger gear?
Hth
Mark A.
What are you asking for the whole winch setup?
Sorry for the ancient bumptasticness, but Im curious too, if anyone has found a source for these? Would it be possible for a machine shop or someone to make one?
18 months and some change later... I dug the box back out.
I'm thinking about completing this in the next year or so. Unless someone wants to buy it.
How much do you want for it...?
I am wondering if anyone has an operating manual for the PTO winch? I am starting to dig through the files that yankeetoys are hosting.
If you swap an H55 and split case into a Cruiser, do you need a different PTO unit at the split case? Are split cases set up for PTO?
since we have the PTO Guru's here.....the pto on my 76 40 pulled weak and briefly....then nada....is there a shear pin? no grinding sounds....just no go, in or out?
Pablo, split case is different from what I understand, and the pics I have seen. I also don't know if the gear is in there. I imagine, like alot of the 75 and up 4 speeds it could be absent to save costs. It would probably have to be sourced. Probably have to get one from a place like GandS, or Specter, or a buddy in Australia.
As far as manuals go, my 1973 owners manaul has a section on winch operation. I sourced a fairly complete PTO settup from a 73 in California, it appeared to be period correct and the instructions work for it. My 1970 Chassis and Body Manual had the proper tear down and assembly instructions in it for that unit. Earlier units appear to be a bit different on the surface, but I think the guts were all about the same. Later units seem a bit different too. Mine had front and rear outputs, and it has forward and reverse. Not all have the rear output and not all will reverse in the PTO box. The TSB's posted earlier in this thread detail a unit without reverse. I do know the owners manaul says to run the PTO with tranny in 3rd gear, transfer in neutral. I assume by running the winch, under load in 1st or reverse may put too much torque to the PTO. So it is recomended to run it in 3rd, a 1:1 ratio. Thus the PTO itself has the reverse capabilities. Perhaps Toyota was having failures running in reverse with the trans, don't know why the differences. I do know the winch is very slow if you use the lower gears due to the rduction at the worm gear in the head. So if you want any kind of line speed out or in for that matter, 3rd is the way to go, or 4th depending on your trans, mine is a 3speed. I do use 1st on occasion when winding by myself so that the operation goes slower, and I don't risk getting caught up as I spool the rope. But you can really run some line out if you want, just floor it :)
40's rock, can you see the driveshaft turning underneath when engaged. If so the pin could be sheared. It is right behind the gear box on the winch head where the drive shaft comes through the frame member. Some put a stronger pin it by drilling it out to accept a regular bolt, as the stock pin is quite small in diameter. Also is the dog clutch engaged on the end of the winch head. When running with the winch in neutral the shaft should turn through the drum, and only winches when the dogclutch is engaged on the end of the drum. If the shaft is turning underneath, and the shaft is turning at the front of the winch gear box, but no shaft turn in the drum, then the worm gear could be toast.
Also, all of the above is for a Toyota winch head, Ramsey also built a settup that would fit a 40, I have not dealt with them. Toyota winch will have TEQ on the side, Ramsey will say Ramsey. They do differ in apperance too.
Beat me to it Pablo, while I'm here and have winch people watching, I need a complete 3 speed shaft for my winch. Mine has been peiced together and is not correct. Seems someone used a ujoint and slip yoke form a Toyota car or maybe pickup on the PTO end. The splines are loose and it wobbles terribly. So is someone has the shaft, and or the U-joint peice that bolts to the PTO box I could use it and will pay handsomely.
Is there a need for these? I can get them made up the same as I had the '55 rear window gears made up. Here's the link on the '55 rear window gears. I could get these made up in whatever material folks want, brass, bronze, steel, whatever.
