Complete PTO Rebuild thread
I'm going to sell it.
18 months and some change later... I dug the box back out.
I'm thinking about completing this in the next year or so. Unless someone wants to buy it.
if someone gave me $150 for this, I might sell it... maybe... its just taking up space.
PM sent.
Does anyone have a list of gaskets/seals/bearings quantities and part numbers required for rebuilding one of these? I got an old one that needs work but don't really know what I need to replace to make it "right"...
TIA!
TIA!
The big thing to check is the bronze gear in the winch head. They are no longer available apparently and they tend to wear.
I have thought about making them up down here in Guatemala where I can get machining cheaper that the states. I have not had much response though from folks saying "Yes, I want one!".
I might be interested, depending on the price. I haven't even torn this one down to see what is wrong/right with it yet, just trying to get some info and start gathering up parts to do the job.
I generally try to replace anything that might be a problem in the future (within reason) so I don't have to go into something twice in the forseeable future. I have looked at some of the diagrams in SOR but it is hard to tell what I need and how many of each thing I will need. I was hoping that someone might have already done the hard work of getting that info together.
Thanks for your reply! Let me know if you decide to get a batch of gears made up.
They leak because of an oil seal failure. Replacements are available from the dealer for something like $5 a pop. The pto takes two. There is another gasket between the PTO and the t-case, also available from the dealer. Total repair for leaks is like $15, 60 minutes of your time, and perhaps a beer or two.
I have never heard of the bronze gear failure in the winch head itself.
Thanks for the info... What about the winch head itself? I would like to replace all of the seals and bearings, if available.
Also, I'd be interested in your PTO shift plate, too, if you are still making those for sale...
Thanks!
Thanks!
Here is a link to FAQ about the PTO winch:
https://forum.ih8mud.com/40-55-series-tech/94874-p-t-o-gearbox-winch-information.html
I have not heard of rebuilding the winch head itself, just have not seen them fail. There is a nice thread about fabricating a support bracket/gusset for the lower housing. Occasionally those will crack from abuse. Here is the link: https://forum.ih8mud.com/40-55-series-tech/208362-if-aint-broke-reinforce.html
I am not saying gaskets or seals are not maintenance on the winch heads, just that I have not had a need to do it.
I sent you a PM about the PTO shift plate, thanks for your interest.
I am leaking at the junction between the t-case and the PTO gear box.
I have heard that the gasket thickness is critical to ensure proper clearance for the PTO gear. Is this true?
Anyone have the p/n for the gasket for a '74 t-case and PTO box?
Thank you!
Replace the gasket. :)
Critical?
It really is a matter of perspective:
It is critical that you do not put your hand into a fan while the engine is running.
It is critical that your gear boxes have proper lubrication.
In the event your PTO gearbox makes a little gear noise during initial install/testing, you can stack another gasket or two at the PTO box and transfer case mating surface to prevent the drive and driven gear teeth from meshing too deep, thus, alleviating the gear whine that can be present with the PTO gear box.
I am aware of only one gasket for this application, and only one thickness from the factory and it is the same as the gasket used for the side cover/PTO block off plate.
36144-60010
Critical?
36144-60010
You sir are a gentleman and a scholar!
Thank you
Going back to the well here to see if I can get some help...
My lower fairlead on my PTO is stuck to the long, shouldered bolt that runs between the plates that mount the upright roller fairleads.
I have been dropping in some PB Blaster and trying to drive the bolt out with a center punch.
No luck.
I left the assembly in the fridge today and then heated the roller with a plumber torch, still no luck.
Does anyone have any guidance?
We do have some -80 freezers at work. I could put it in there and try heating the roller. Not sure if that would be a little too drastic...
Any help is appreciated!
