Cold start question
Columbia South Carolina and Cedar Mountain NC
Have a 1972 FJ40 with a 2F engine with a 1972 Aisan carb. It ran very rich when I got it with black soot coming out the pipe and terrible gas mileage. "High altitude" jets were replaced with smaller jets and carb was adjusted to run lean. Now its clean and gas mileage is much better and no soot. When warm it starts up within a couple seconds without even pumping gas. When sitting for a few days it takes sometimes several minutes to turn over. I've tried no gas, pump 1-4 times, choke in, half way out, all out. Sometimes it smells like flooded and I wait and then it starts more quickly. Is this a problem with the bowl or something else or me? I am only using ethanol free 90 octane gas.
high altitude jets are the lean jets in the carb.
sounds like the gas in the bowl is either draining out or evaporating off, then the fuel pump is struggling to refill the bowl.
Mine does the same thing. I believe it is the gas draining out of the gas line and it will start once the bowl fills.
Is there a electric fuel pump kit available from a vendor ?
I’m not aware of a kit.
You’ll need to assemble wiring and connectors, to wire it (just 2 wires) and plan how to hook it up... since the oem pump is mechanical.
You may also need some new soft fuel line... I would replace soft fuel lines, while installing... just to make sure all is well in the soft fuel line world.
Mount the electric pump lower than the feed port on your tank, near your tank, and connect to the feed line in the PS frame rail.
Assuming your fuel delivery system is oem, disconnect the soft line, from the carb side of the fuel filter, and run soft fuel line, bypassing the mechanical pump, to the hardline that runs around the front of the valve cover, to the feed port on the carb.
Some people connect the electric fuel pump inline with the mechanical pump. But, Carter says that can damage the electric pump.
I removed my Mechanical pump and used a BBC Blockoff plate to cover the hole in the block.
I have two tanks, each with its own pump & filter. So, as long as I keep fuel in the inactive tank, it’s merely the flip of a switch, should the active pump fail.
I also carry the mechanical pump and soft fuel line as a tertiary Backup ... in case I have a problem that impacts both pumps... playing a long game here. :rolleyes:
I use Carter P4070 fuel pumps, they generate ~3-5psi, which is what’s needed by a OEM Aisan 2bbl carb.
Anyone considering an electric fuel pump should also consider installing an Oil Pressure Safety Switch (OPSS). I use a Carter A68301 and a “Squirrelly Oil Pressure Sending Unit Adapter 1/8" BSPT Port Male Female T' “, to T into the oil pressure sender fitting. Three wires.
The OPSS shuts off power to the electric fuel filter, when oil pressure drops below 2psi. This prevents the electric fuel from continuing to pump fuel after the engine quits. The OPSS allows the pump to run when oil pressure is <2psi AND the ignition is in the “start” position... to allow you to start the engine.
I also have a Pollak 6-port electric switching valve, to proper select between fuel tanks, based on power sent from a DPDT toggle switch, on the dash... selects the active tank.
The Pollak also selects the proper fuel send ( main or aux tank) and displays the active tank fuel level to the OEM gauge.
Full disclosure: a few months back, my oem fuel gauge quit displaying fuel level for my aux tank. I replaced the fuel sender... no luck. I replaced the Pollak... no luck. I replaced wiring runs... no luck. I spent too much time an put off too many trips... no luck. So, I gave up and installed an aux fuel gauge... it appears the my sux problem is related to the built in regulator in the oem fuel gauge... but... I’m fine with the aftermarket aux gauge.
Below freezing, I pull the choke all the way out, push the pedal to the floor, crank it over.
Fires right up every time, after it starts I push the choke back in until it is at a nice idle, I leave it there until I drive off.
Early fuel pumps have a hand primer which allows you to fill the bowl in the carburator before you ever turn the key. My cruiser set at our cabin sometimes for months. This cuts down the number of of cranks before the engine starts to just a couple. It's stock which I like. Not as easy as a electric fuel pump. But driving a FJ40 is not like driving our modern DD and the hand pump is just another part of the experience.
Be sure that the choke is totally pulled out. I use some Triflow on the outside sheath of the cable and grease on the carb idle speed cam.
Make sure stock size jets are all in place and float height is set correctly. Cold start should usually always require full choke, if not, carb is a little too rich or you live in the desert and its always hot. Once running, check fuel level in sight window. Then the usual checks, vacuum at idle, timing, valve adjustment. Once they are all set correctly and vacuum is ~20 you should have solid starts.
If you can't get it to fire up with full choke and requires more than three full presses on the throttle, there are some issues to sort through. My truck initially took 6-10 pumps and full choke to start up. After running through the motor and verifying everything is setup correctly, its full choke and one pump and she fires right up from cold. 3 pumps max if its been sitting in near zero degree weather.
Seems to turn over better without choke, however it can take several minutes of cranking, and once catches I pull full choke which increases idle speed at same time. Once warm I push choke in and it idles very smooth at about 650 rpm on digital gauge cluster. After morning start it restarts with barely a crank.
The sight glass shows fuel halfway up after started and seems to drop after a day or so.
How does the mechanical fuel pump fill the bowl? Cranking? Pushing throttle pedal?
The mechanical fuel pump has a rubber diaphram that gets moved up and down during cranking, it sucks fuel from the tank. Fuel pump also has check valves that are supposed keep fuel from flowing backwards during cranking. I would think if crud gets in the check valves, filling your carb bowl would take longer. Once the fuel pump has fully filled carb bowl, pressing throttle pedal gives a big fuel squirt. On your mechanical secondary Aisan, flooring throttle pedal also opens both butterfly’s.
If your cold start issue is priming the fuel bowl, you might try no choke(as you’ve observed) and hold throttle pedal to floor during first couple cranks. This may allow your engine to turn over a bit quicker resulting in bowl filling up sooner. Once you think bowl should be full, release pedal. Pull choke and turn over engine again. During cranking quickly pump throttle pedal to floorboard a couple times or however many your particular engine needs. This will squirt fuel into air flowing to pistons.
I pump the gas 3 times, pull the choke all the way out and turn the key. Engine will crank for a second or two and fire up. This works even if it has been sitting for a month or two. Once it's running I push the choke in 3/4 of the way and let it idle for a minute or two before pushing the choke all the way in and driving off. My 76 carburetor was rebuilt by Jim C almost 20 years ago and I have a gear reduction starter, both of which seem to help with startups. Good luck! :)
The fuel pump only fills the bowl when the float level is down, if the carb is in good shape, check the sight glass. You may want to run 87 or 88 octane, especially when cold. Have you "read" the spark plugs, they reveal quite a bit.
Running lean is not ideal for longevity sake because it gets too hot and burns too quick. Do you have any desmog done on your 2F; what year of motor is it? Did the F distributor get swapped with the carb?
How does 87 octane help?
Sight glass is half full after start up and drops after a day or so.
The engine is a 1978 I think. Someone grinded off the serial number. The Aisan carb is 1972. Here is pic of dizzy and carb.
There is a charcoal canister, and Vacuum
Switching valve so don’t think it was desmogged.
It was running very very rich with soot inside pipe before leaned. Have not rechecked plugs.
Octane is a combustion inhibitor. The more octane, the more you inhibit combustion. 90 octane is for high compression motors, because, higher compression contributes to pre-ignition, you run 90 so that the ignition is timed with the moment of spark. It is probably overall inconsequential in regard to most of the problem you are experiencing, but it isn't helping either.
You could have a vacuum leak that is making things difficult. When did you inspect the PCV system last? The PCV valve is usually okay after a good cleaning. Others have reported cracked intake manifolds, and I see that you have headers (where the exhaust manifold would have mated). Have you checked the torque on the nuts that hold down the carb, it looks wet around there.
Reading plugs will give us a general clue as to a rich or lean condition right after start-up.
Have you checked your timing? Be sure to have your distributor seated far enough down if you make any timing adjustments, because it is critical for the engine's oil pump.
What they said... No gas in the bowl.
I just turn the key, let my electric fuel pump run for a few seconds and then turn to start and she fires right up. :cool:
Same with my 77
I see you have a 72 but using a 2F engine with a points dizzy. As far as I know 2F engines came with semi and full electronic ignition systems.
I was going to say that sometimes we hook the positive terminal of the ignition coil to the ignition (key side) circuit and disregard the jumper from the armature of the starter solenoid, which if correctly wired will give the ignition coil full battery voltage on initial or cold starts; otherwise there will be a voltage drop from the key side ignition wire because of instrument gauges and indicator circuits.
Sight glass is empty after several days. Cranking without throttle or choke for 5-10 secs fills sight glass 2/3rd full. Then pushing throttle several times while cranking and it starts however I have to keep choke all in until it just catches and then pull out to warm engine.
This is the dizzy.
