Is there a electric fuel pump kit available from a vendor ?
I’m not aware of a kit.
You’ll need to assemble wiring and connectors, to wire it (just 2 wires) and plan how to hook it up... since the oem pump is mechanical.
You may also need some new soft fuel line... I would replace soft fuel lines, while installing... just to make sure all is well in the soft fuel line world.
Mount the electric pump lower than the feed port on your tank, near your tank, and connect to the feed line in the PS frame rail.
Assuming your fuel delivery system is oem, disconnect the soft line, from the carb side of the fuel filter, and run soft fuel line, bypassing the mechanical pump, to the hardline that runs around the front of the valve cover, to the feed port on the carb.
Some people connect the electric fuel pump inline with the mechanical pump. But,
Carter says that can damage the electric pump.
I removed my Mechanical pump and used a BBC Blockoff plate to cover the hole in the block.
I have two tanks, each with its own pump & filter. So, as long as I keep fuel in the inactive tank, it’s merely the flip of a switch, should the active pump fail.
I also carry the mechanical pump and soft fuel line as a tertiary Backup ... in case I have a problem that impacts both pumps... playing a long game here.
I use Carter P4070 fuel pumps, they generate ~3-5psi, which is what’s needed by a OEM Aisan 2bbl carb.
Anyone considering an electric fuel pump should also consider installing an Oil Pressure Safety Switch (OPSS).
I use a Carter A68301 and a “Squirrelly Oil Pressure Sending Unit Adapter 1/8" BSPT Port Male Female T' “, to T into the oil pressure sender fitting. Three wires.
The OPSS shuts off power to the electric fuel filter, when oil pressure drops below 2psi. This prevents the electric fuel from continuing to pump fuel after the engine quits. The OPSS allows the pump to run when oil pressure is <2psi AND the ignition is in the “start” position... to allow you to start the engine.
I also have a Pollak 6-port electric switching valve, to proper select between fuel tanks, based on power sent from a DPDT toggle switch, on the dash... selects the active tank.
The Pollak also selects the proper fuel send ( main or aux tank) and displays the active tank fuel level to the OEM gauge.
Full disclosure: a few months back, my oem fuel gauge quit displaying fuel level for my aux tank. I replaced the fuel sender... no luck. I replaced the Pollak... no luck. I replaced wiring runs... no luck. I spent too much time an put off too many trips... no luck. So, I gave up and installed an aux fuel gauge... it
appears the my sux problem is related to the built in regulator in the oem fuel gauge... but... I’m fine with the aftermarket aux gauge.
