Can anyone explain the best way to remove and replace the choke pull and cable on an FJ40? I've done a search and can't locate much on this.
Background: last weekend I started to replace the Weber carb (with electric choke) that came in my '74 with a new Trollhole carb. The manual choke cable is still there, just disconnected in the engine compartment.
But the cable doesn't seem to work. It's very hard to get the knob to move (I can only pull it out about a half inch). So I'm assuming the cable needs to be replaced.
I'm pretty sure the pull is held in by a single nut behind the dash, but is there a good way to access it? The metal ring on the front of the dash will not budge.
Thanks.
Thanks.
and hoops.
