Build Chicago builds a 40
This F*CKING fuel tank thing is GONNA KILL ME!!!!
It is absolutely F*CKING ridiculous how lawyers, insurance companies and law suits have totally F*CKED UP this once great company...
TRUE STORY...
I called to get some dimension and info on an aftermarket tank that is specific to a particular vehicle. Dude on the phone WOULD NOT answer ANY of the questions I had re. this tank because of the fact that I said it was for a custom application...why..."for insurance reasons we can not suggest or encourage its use for any other application accept for its intended model or design."
NO FU*KING WAY!?!?!?!?!
I cant even get an idea if the F*CKING TANK is position specific?????
The down fall of American society!!!!!
Truly a shame!
TRUE STORY...
Truly a shame!
come across that a few times myself. Pretty unimpressive.
unbelieveable! I was almost STUNNED.
Its actually VERY IMPRESSIVE the power the lawyers levy on the whole nation. Its SOOOOO fawked up.
Im just gonna build this thing myself. F it! Im gonna get the dimensions down this week and take it to the steel shop and have them brake it for me.
This is one thing that has been naggin me since I discovered that I had to cut out the tank pan...quite a while now. Time to get it done and move on.
I wouldn't blame the lawyers 100% they wouldn't be in business without greed. And people who want something for nothing.
BTW coffee can be hot, ice is slick, and alcohol can cause health problems. All opinions expressed in this post are solely that, opinions, IH8mud, chicago, the United States, Nevada, and the IRS are in no way responsible for the content. Side affects may include vomiting, skin rash, diarrhea, loss of memory, loss of hair, stroke, heart attack, partial paralysis, short and long term memory loss, and in some rare cases death. If you notice any of these symptoms, including death, discontinue use and consult your prescribing physician immediately. Please read and follow all safety instructions, failure to do so may result in injury or death. Avoid prolonged contact, breathing dust or vapors. Use in a well ventilated space. Do not use for heating or in enclosed spaces. Wear eye and hearing protection at all times. CAUTION! high voltages present.
El café de BTW puede tener calor, el hielo está resbaladizo, y el alcohol puede causar problemas de salud. Todas las opiniones expresados en este poste son únicamente eso, las opiniones, Chicago IH8mud,, Estados Unidos, Nevada, y el IRS no son de ninguna manera responsables del contenido. El lado afecta puede incluir vomitar, erupción de piel, la diarrea, la pérdida de memoria, la pérdida de pelo, el golpe, el infarto, parálisis parcial, pérdida corta y a largo plazo de memoria, y en alguna muerte rara de casos. Si advierte cualquiera de estos síntomas, inclusive la muerte, discontinúa el uso y consulta a su médico que prescribe inmediatamente. Lea por favor y siga todas las instrucciones de la seguridad, el fracaso para hacer así puede tener como resultado herida o muerte. Evite contacto prolongado, respirando polvo o vapores. Utilice en un espacio bien ventilado. No utilice para la calefacción ni en espacios encerrados. Lleve la protección de ojo y oído siempre. CUIDADO! voltajes altos presentan.
Le café de BTW peut avoir chaud, la glace est glissante, et l'alcool peut causer les problèmes de santé. Toutes les opinions exprimées dans cette poste sont seulement cela, les opinions, IH8mud, Chicago, les Etats-Unis, Nevada, et l'IRS est nullement responsable du contenu. Le côté affecte peut inclure vomir, l'éruption de peau, la diarrhée, la perte de mémoire, la perte de cheveux, le coup, l'assaut de coeur, la paralysie partielle, la perte de mémoire courte et à long terme, et dans quelque mort de cas rare. Si vous n'importe lequel remarquez de ces symptômes, y compris la mort, interrompre l'usage et consulter votre médecin qui prescrit tout de suite. S'il vous plaît lire et suivre toutes les instructions de sécurité, le non-respect peut avoir pour résultat la blessure ou la mort. Eviter le contact prolongé, respirant de la poussière ou des vapeurs. Utiliser dans un espace bien ventilé. Ne pas utiliser pour le chauffage ou dans les espaces enclos. L'oeil d'usure et entendre la protection à tout instant. PRUDENCE ! à haute tension présente.
Кофе BTW может быть горячим, ледяной является гладким, и алкоголь может вызвать проблемы здоровья. Все мнения, выраженные в этом посте - исключительно, что, мнения, IH8mud, Чикаго, Соединенные Штаты, Штат Невада, и ИПС никоим образом не ответственны за содержание. Сторона затрагивает, может включить рвоту, сыпь кожи, диарею, потеря памяти, потеря волос, удара, сердечного приступа, частичного паралича, короткой и долгосрочной потери памяти, и в небольшом количестве редкой смерти случаев. Если Вы замечаете любой из этих признаков, включая смерть, прекращаете использование и консультируетесь с вашим предписывающим врачом немедленно. Пожалуйста прочитайте и следуйте за всеми инструкциями безопасности, отказ сделать так может привести к ране или смерти. Избегите продленного контакта, вдыхая пыль или пары. Использование в хорошо проветренном месте. Не используйте для нагревания или в замкнутых пространствах. Глаз изнашивания и слушание защиты всегда. ПРЕДОСТЕРЕЖЕНИЕ! высокий подарок напряжений.
BTWコーヒーが熱いかもしれなくて、氷が滑らかで、アルコールは健康問題を引き起こすことができます。 このポスト〔郵便〕で表された全ての意見が単にそれで、意見、IH8mud、chicago、アメリカ合衆国、ネバダ、及びIRSは内容に決して責任がありません。 側 影響する 吐くこと、皮膚吹き出物、下痢、メモリーの損失、髪の毛の損失、一撃、心臓発作、部分的な麻痺、短編、及び長期記憶損失を含んでいるかもしれない そして いくつかのまれなケースで 死。 もし死を含むこれらの徴候のどれも中止になることに気付けば直ちにあなたの処方内科医を使って、相談してください。 全ての安全指示を読んで、従ってください、そうすることへの不履行が傷害か死に終わるかもしれません。 延ばされた接触〔連絡〕、呼吸しているほこり〔粉末〕、あるいは蒸気を避けてください。 よく換気されたスペースの使用. 暖房のための使用も中に同封されたスペースもしないでください。 いつも視力及び聴聞会保護を身に付けていてください。 注意!電圧が示す最高水準。
BTW 咖啡可以热,冰是光滑的,酒精可以导致健康问题。所有见解以这个职位表示完全是那,见解, IH8mud,美国内华达芝加哥,以及 IRS 一点也不对内容负责。边影响可能包括呕吐,皮肤皮疹,腹泻,记忆的损失,头发的损失,中风,心脏病发作,部分瘫痪,短和长期记忆损失,在一些少见的案例中死。如果你注意到这些症状的任何,包括死,停止使用和立即咨询你的规定内科医生。请阅读和按照所有安全指示,未能这样愿导致受伤或死。避免延长联系,喘息灰尘或蒸汽。使用在一个好地通风的空间。不用于加热或在圈住的空间。穿戴眼睛和始终听到保护。警告!高电压存在。
Dude
dude!!!! Now that is some funny stuff right there!!!
I try.
Take good notes on you tank build, some of the rest of us might be interested in duplicating it. I'd even sign a liability waiver.:flipoff2:
you gotta tig to put that tank together? I personally wouldnt wanna mig one, too many pinholes could pop up easily IMOP. plus TIG would be bling looking.
Nope...MIG is what I got, MIG is what Ill use.
you go over it enough, youll fix the leaks.:grinpimp: I WILL be pressure testing it probably numerous times as well.
I've looked at a lot of older "home made" style oversized gas tanks that were used for years and years and at best they were mig'ed.
I say mig that bitch.:D
Jack
Jack
I was thinking it would be a good excuse for him to buy a TIG set-up.
No s***! I've been wanting to learn TIG.
Come on Keith: JUST DO IT...take one for the team. You KNOW you want one :D
Keith you'll love TIG, even I can make welds that look decent and are whithout leaks. I just got myself a nice present that might be interesting for you when you make your own tank. This can make all kinds of profiles and rims in sheet metal. And this, a shrinker expander for bends in profiled sheet.
Okay....Ill DO IT!
All you guyz have to do is give me the money and well get this ball rollin!!! It shouldnt be THAT much divided among all of you. Ill even chip in a couple hundred for the "cause"! That's just the kind of guy I am!:flipoff2:
My dad was a welder and machinist by trade. He used TIG almost exclusively. He was and still is GREAT at it. I had ran a few beads with his set up several years back when I got into this game.
I DO peruse CL for a set up from time to time, but...its a REALLY EXPENSIVE set up and its also a constant cost for consumables as well...toungston rod for the tips, gas bottles, filler rods, torch cups...Miller has a nice little self contained unit out now, and that is 1800 bucks.:eek:
Bottom line...NOT HAPPENING!
Right now at least!
Okay....Ill DO IT!
Right now at least!
Can we just borrow your Dad's set-up? :D
Okay....Ill DO IT!
All you guyz have to do is give me the money and well get this ball rollin!!! It shouldnt be THAT much divided among all of you. Ill even chip in a couple hundred for the "cause"! That's just the kind of guy I am!************
Right now at least!
Somehowe I knew you where going to say that.:rolleyes:
Have you got a plan for the tank yet?
Have you got a plan for the tank yet?[/QUOT
Yap! Basic cube 25 x 20. X 8/9 (depending on the sending unit). Sump, baffles, pick up, return, vent, drain plug and a capacity just over 17 gal. I think I have it figured that I'll be able to use the stock filler assy. Will be supporter by 4 bolts similar to that of a shock where the bolt will go through a bracket, mounted off the upper, rear shock mount and the wrap bar x member. Gonna do a mock up out of cardboard this weekend and see if I'm missing anything. Probably gonna use a heavier ga. Steel for welding purposes to minimize burn through.
Sound like a plan?? :)
