Marriages too! Maybe not all...Could use something like lectra motive or maf cleaner. Time, fresh air and heat will heal all charcoal wounds.
The check valve on the stock canister can be cleaned/repaired. It's your only hope of passing smog in California. Since 2015 they have to do a visual inspection and fail you for any parts that are not stock or stock replacements. The vc120 that I used To cure my tank VACUUM problem, is plastic, obviously a different size and the hoses have to be rerouted. Maybe it will pass smog in a non-communist state, but not in Cali.
The bottom air line. The durmast model doesn't have a port. The AC Delco model does. It would take pretty good and someone familiar with 80s to see that mine is not stock. Used SS long screws and flipped the lower band so the bracket wouldn't hit the use/relay box. All 3 hoses routed with a new lower hose. Ill find out in a month when I go for my annual checkup.I know Cal is strict with inspections, but how can they determine if a duralast charcoal canister is a correct replacement part and which models it's a correct replacement part for? Two top lines going to and coming from the same places, what to question?
Worked fine for me.I know Cal is strict with inspections, but how can they determine if a duralast charcoal canister is a correct replacement part and which models it's a correct replacement part for? Two top lines going to and coming from the same places, what to question?
I went to Thompsons In Placerville and the guy said "you passed the computer test, but you are in violation of modifying the original parts. "He said he would pass it this time, but promised it would never pass again.
Post #44 solved it for me.Anyone have the part number for the Delco version? And what store did they get t from? My VatoZone is showing the VC120 as discontinued.
air should be able to flow into the canister through the tank pipe
