Yes, if they are installed correctlyon a 40 with a 2.5 inch OME spring lift are 2* caster shims beneficial?
Not with manual steering.Yes, if they are installed correctly
If my memory serves me correctly, I think Nolen installs 4* shims on all of his builds with lift springs, and I've only ever seen him use the 2"-2.5" kits on the market. So, you could likely benefit from more than 2* caster shims with a stock housing.....
So its a what is everyone else doing?
The caster shims was the single best upgrade/fix I did. It made Yellr feel so much safer. Like mentioned mentioned… shopping cart but sans wobble. It was the difference for me feeling safe taking a curve in the road at 45 then vs 60/65 now on the highway (speed limit is 65). I only have from shims.Bob, I put 4* correction shims in the front and it made a huge difference in how my 40 handled.
Approximately 2” lift.
33” tires.
Saginaw Power steering (3.5 turn box).
Bryan @OlYellr has my same setup but manual steering, perhaps he’ll chime in as well?
My trucks didn’t need them in the rear.Of course my 43 wonders! I chase it side to side constantly! I was thinking it was my 40 year old TRE’s or my center arm causing the wonder? As I reviewed my wondering issues it made me think of the caster shims and how they could make a difference. Sounds like it will? It’s funny because I didn’t think twice about castor correction for my 80 after a lift.
@Ol Yeller and Ian did you guys shim the rear?
Thanks everyone for chiming in. I’ll get back to this in many days from now after I do the Fing work.
This reminds me of a quote from JRR Tolkien “all who wonder are not shimmed”
Peace out!
Oh, probably wouldn’t hurt to put new TREs in there as well.My trucks didn’t need them in the rear.
Measuring the angle can be a little confusing, especially in the front, but it’s worth doing if nothing more than getting a data point.
Call me if you have questions.
I don't have them on mine.
2½" suspension
31x10½ tires.
It might benefit from them, but what i notice the most is when a road is pounded in and my track width doesn't match the ruts in the pavement. Not sure much can be done about that.
Shims should help it track better. Especially with a worn road.
Bushings and springs are fresh. I’m definitely changing the TREs. Center arm adjusted per FSM.Oh, probably wouldn’t hurt to put new TREs in there as well.
How are your bushings?
