- Joined
- Jun 11, 2013
- Threads
- 68
- Messages
- 1,506
Man o man once again so much help on this forum, this last bit of information has helped me gather the last of the seals, that I needed.
That's awsome, you said he also has the rubber that accepts the chrome trim?
That would be too easy.
also, are you sure the 60 are available?
Have you tried emailing one of the gasket companies to see if they have sharp corners for the bulk rubber they sell?Apologies in advance for my obsession with this issue.
The Pig gasket profile seem pretty generic and shouldn't be too hard to find a substitute if I guy was truly obsessed....
One of the billion China gasket companies.
boat window rubber gasket seal - Windscreen rubber seal, Windscreen rubber seal, window gaskets and seals, window rubber gasket, - ABCRUBBER INC.
boat window rubber gasket seal is manufactured by high quality epdm. It is mounted around the glass window with a large range of applications including cars, trucks, trailers, caravans, high-duty equipment, boat, etc.www.abcrubber.comTruck Bus Car Back Windshield Rubber - Windscreen rubber seal, Windscreen rubber seal, window gaskets and seals, window rubber gasket, - ABCRUBBER INC.
is made from the imported epdm materials. Mainly used between the window and the windshield to provide a stronger grip of the window glass. It is also suitable for the seal of the glass and the glass run channel.www.abcrubber.com
More options.Did you ever try to source the seal that accepts the chrome trim?
More options.
The best eCommerce platform for driving sales | 3dcart
An all-in-one solution perfect for beginners and experts alikestores.restorationspecialties.com
