- Joined
- Mar 4, 2018
- Threads
- 14
- Messages
- 1,184
Wonder how many needles I'm gonna break! Hehe
I would sandwich the fabric as mentioned above and use some fabric adhesive sheet (the iron on kind) to hold it together before attempting to sewWonder how many needles I'm gonna break! Hehe
Mine are reinforced as well but Sean's are double stitched and mine are single stitched. There were some interesting design changes between the two.I've got the basic one. Still seems to have reinforced anchor points![]()
My wife made mosquito nets for two of my hammocks out of Walmart sheer drapes. They work really well but do not breath at all.Smart, thanks y'all
only holds 300lbs though, those are rookie numbers, need to get those numbers upIn case any of you vertically-nonchallenged people (@lt1fire I'm looking at you) need a cot, this is an option and is USA made.
Green Bighorn Roll-a-Cot ®, 84"x32"x18", with 3 leg frames and sleeve for your air mattress
The Bighorn Ibex Roll-a-Cot ® is the ultimate in portable sleeping comfort. Comfortable Top: Slide your mat into Roll-a-Cot's sleeve and it will stay put all night long. Fits Air Mattress up to 25" wide x 2" Thick. For more information see this...www.camptime.com
Genius! just a big tarp.
Giggidy?...or in it.
Tail pipe hotdogs are the best!Forget about the fumes! All part of the experience! And you can cook hot dogs on the tail pipe!
specialtyoutdoors.com
super nice for a Hundy.I just bolted on a new Napa Maxi Trac awning (basically an ARB rip off). And then I found the FB support group
Seems that the construction is not entirely up to snuff and the members in that group have posted alternative ways to beef up the factory rivets and such.
My first impressions are that it's damn near identical to the ARB in design - same extrusions, similar hinge brackets (albeit aluminum instead of ABS) and the canvas seems very similar too. The outrigger legs don't have the ground pins or rope loops on the feet, but if you properly guy-rope it, I don't see it being a problem.
Not bad for $100.
