^^no idea why I never thought about that^^Use a chisel or screwdriver to put a small puncture in the oil filter while draining the oil to reduce the amount that pours out when you remove the filter.
).If you're missing the 6-disc changer (back of centre console) and want one, let me know... I have it and won't be keeping it. Any of it.
Still wondering why it needed the tap. I will probably take a closer look when I get around to it and just make sure the bulb is seated properly or just put a new one in. Thanks for the tip. Always good to learn something new about these trucks.
Mine is like that too. If I notice it's out, I knock on the plastic at the base of the shifter like knocking on a door. The light always comes back on. It's almost endearing how it responds to a knock.
Not to thread-hijack, but if Rockfox doesn't want it and it's reasonably close to working order, I'll take it. Mine is starting to ERR 21 about 90 percent of the time that I try it.
All yours !Not to thread-hijack, but if Rockfox doesn't want it and it's reasonably close to working order, I'll take it. Mine is starting to ERR 21 about 90 percent of the time that I try it.
Just want to say that I picture you as a man smoking a pipe while sitting in a rocking chair while you regaled us with your witty anecdotes and yarns. I like the cut of your jib.@ROCKFOX Everyone has their own opinion on oil, some are based more on science others on tradition and some just on experience. Personally the only one I avoid is Pennzoil. I like Full Synthetic but some people recommend against it as some gaskets/seals were not designed with it in mind. There are a lot of threads on it, and you will read some pretty crazy stuff but there are good recommendations. DO NOT expect to get 10k out of any oil in these rigs, they weren't designed to go that long and well you will run out of oil if you have the Toyota rustproofing that most of us enjoy. About the Drip molding,, most people remove it and just clean that area up as there is paint under it and it looks better generally without the molding.
This sounds like your hobby vehicle so you aren't going to break something and miss work etc, so don't worry about breaking things, you have time to fix them and this forum will show you how to fix anything with just a few searches.
Download a PDF of the factory service manual...lexus version and toyota version are not that hard to find. In short loosen the oil cap, put a oil drain pan under the drain plug. remove the plug... (practice will make this part cleaner with time), let it drain out. Then on the drivers side of the engine get two hands on the oil filter and twist it counter clockwise (might need to wiggle your ears and grit your teeth to get it loose) YOu can also use oil filter wrench. I cut the bottom off of a 1 gallon water jug and made a notch to slid under the filter so it catches the oil that comes out of the filter (others may have better suggestions). I unscrew the filter and make the gasket from the old filter touch the new gasket on the new filter. (This applies oil to the new filter gasket which is required). Screw on the new filter (i do mine two hand tight, some people do them tighter, but don't over do it or it will be hard to get off and someone will have to show you the screw driver method).
Put the drain plug back in (recommended you use a new drain plug crush washer that is very cheap) and torque down to factory recommendations (if you are in to that sort of thing). put in about 7.8 quarts of your selected oil (just gauge using the dipstick). I keep a quart or two in the battery box for backup later. Put the oil cap back on and tighten by hand. double check the oil level later to make sure it all settled well after driving <--this will make you feel better until you've done it a few times. Take the old oil and put it in containers for recycling at autoparts stores(Free) or a recycling center (free) you might even be able to take oil filters someone else can chime in there.
Making the internet Classic!You're like old man internet coming in to tell us how it really is.
