Questions about 91 3fe:
1 valves. After head being resurfaced the clearance should have decreased by the removed amount correct so is that not too tight to run engine with? Folks keep taking about adjusting then with engine running. So loosening and tightening that screw and nut while the rocker jumping around?
2 obd engine parameter readers. On these older ones the water temp mod can’t be done, will this older obd give info on the fly to a smart phone with a Bluetooth dong?
3 oil. You folks like 15w40 in these? Only 15w40 at my local maomart was labeled for diesels. That matters not?
4 prop shaft grease? What flavor? On aircraft ya supposed to never interchange greases, what’s recommended for these?
5 brakes. Watched a YouTube vid talking about hi temp fluid and performance pads? What’s the common issue causing spongy or unresponsive on these?
6 fuel rail copper washers. Seems stack up in picture and when I removed them was kinda weird. Seems to me the bigger gas pas through bolt had 2 washers against rail wind 1 under the bolt head?
7 over services transmission. Po had said he replaced a buncha fluids and musta misread how much to add? Or is that indicative of different problems?
8 why does the fsm have you jack the truck up to get exhaust on?
