Buncha questions sorry
So are you comparing a 20+ year old 6000 lb vehicle to a 2018 sports sedan? In that respect, the brakes are inferior. That is also not a valid comparison.
I can say confidently that the brakes on our 2016 kia sedona are an order of magnitude better than the land cruiser. Vacuum boosted. Heavy turd of a vehicle.
What advancements in braking technology do you believe are relevant here?
Sorry, I don't understand the question. My brakes work very well.
I get that braking systems on new vehicles probably have improved significantly, in that they offer more control via electronic means, but the 80 series brakes themselves are capable of locking the tires. What more do you want? The tires to spin in reverse?
When I go from driving my 80 to my wife's '13 Kia Sportage it's a world of difference in amount of foot pressure needed to stop the vehicle. There's times my wife thinks I'm stopping to avoid a wreck when in reality I'm just applying the pressure I would normally use in the 80.
So, are the brakes actually better, or are they just more boosted?
In the 2014 Highlander, I felt like everything was "boosted". Barely press the throttle and BAM you're accelerating. Push it to the floor and you're barely accelerating any harder. Same with the brakes. Very touchy, but not necessarily able to stop the vehicle much faster.
Does the Kia have better feel? Does it stop the vehicle any faster (aside from weight difference)?
I honestly don't know what braking advancements have been made, aside from better cooling and newer pad and rotor composition?
Agreed that cars have different 'feels'. People who drive the 100 series often come away with the impression that the brakes are much better than the 80 simply because it takes less pressure to engage them. That's subjective, people may prefer the feel, but it doesn't make them 'better'.
by that logic, why even have a power brake booster? or power steering?
there is not enough feedback in the pedal, the brakes on the 80 are notoriously mushy and soft, and they run through consumables rapidly. The number of threads on here about the s***tiness of the 80 braking system should be evidence enough.
IMO the cruiser should have come with a bigger booster, a larger master cylinder, and larger calipers.
The majority of people prefer that feel. And if we're talking about subjective opinions on the 80 series brakes, I think it's reasonable to respond to people who say "why do my brakes feel lousy" with "well, pretty much, by most people's definitions of what good brakes are like, the 80 brakes suck"
Most complaints are from people who genuinely have a problem with their brakes. To just say 'the 80 series brakes suck' tells them that there is no hope for them to have normal brakes, just accept that you can't stop your truck and pray the busload of nuns sees you coming and gets out of the way. The 80 has a brake booster, it works well, the brakes are not as sensitive as those on some other vehicles. Some people see that as a positive. Bottom line, when working as designed, the brakes should stop the vehicle in a reasonable distance with a reasonable amount of effort.
So 19 years younger, and 1000 lbs lighter is a fair comparison? C'mon man.
My wife's 2016 3 Series has really good brakes too.
I dunno. My brakes are better with 1980s era calipers on 42s than they were with the toyota brakes on 37s. This seems like Toyota fanboyism again
A Kia Sedona is an embarassing blob of korean cheapness so I think it's not a comparison at all. And what do you mean the 3 series has really good brakes? Are they better than the land cruiser?
Being able to lock the tires is a poor metric. Any- ANY- properly adjusted and maintained braking system has the ability to lock the brakes. Airplanes, trains, bicycles and handicap scooters all can lock their brakes if you disable the anti-skid and jam on the pedal/pull the lever hard enough. The systems ability to cope with, absorb and dissipate heat without much degradation in brake pedal feel or stopping distance is. And by that measure, the Cruiser brakes are marginally adequate. They're good for one panic stop from legal highway speeds before they're heat soaked and will require some time to cool. Most non- performance cars are like this. However, knowing the limitations makes me think about braking distances way more in my Cruisers than I do my car.
As for modern car vs. LC80, I could say my Jaguar XKR stops better therefore LC brakes suck, but the spoiler alert is that my car weighs over a ton and a half less, has rotors as big as FJ80 wheels, and pulls a hair over 1G on the brakes with street tires, so by that standard almost anything on the road is going to suck in comparison.
You put 1 ton axles and 42's (and brakes I assume) on a 1/2 ton vehicle and say they are more capable than the stock parts on 37's? Another great comparison.
All my comparisons have been with Toyota vehicles, not sure how that equates to Toyota fanboyism. I wouldn't defend the 80 brakes if they didn't work. I wouldn't even be shocked if the Toyota brakes were s***ty with oversize tires, but they aren't. We do see a lot of complaints about brakes, and the typical 'they can't be fixed, they suck' attitude will get people hurt. They don't suck. At least they shouldn't, and if they do you should be looking at why, not just blaming it on the vehicle. It can be challenging to get them working properly, which does in fact suck, but it can be done. There are many 80's around here with good brakes. Complaints get posted, people don't post when there isn't an issue. This is the head gasket all over again, which you are probably loving. :flipoff2:
I can lift the back wheel off the ground if I grab a fist full of front brake on my RC51. My 80 can't do that, so the brakes suck. It's simple comparative logic, man.
This is a fair argument. The issue I have with it is that often the people who complain are not able to lock up the tires, because they are not properly adjusted or maintained. I have had several people bring their trucks to me to test drive and fix, and I was scared to drive them- their brakes sucked, and they needed to be fixed. It's common, and shouldn't be ignored because people hear that they just have to put up with it, that the system is not capable of proper braking.
When put that way, I will completely agree with you.
The brakes on my 80 are GREAT! They are power, and so is the steering! The RR one hangs a bit if I do panic braking. But that's only enough to throw it into a hard roll if I'm doing 90.......
Now.....go back another 37 years and drive one from that era. Drum brakes all four corners. Guess what? If they are adjusted and maintained PROPERLY, they work GREAT!
When I first got my 80, it needs brakes BAD because they pulsed, faded, and the pedal was generally mushy because the PO didn't take care of it.
After new rotors, pads, calipers, and brake hoses...It's great and probably the bet feel of ALL my vehicles... Until I just bought a 2009 Chrysler T&C. So there is something newer in the stable....
I had struggled with trying to improve the brakes. I replaced all four calipers, new pads all around, new MC, new booster and new front Power Stop rotors. I didn't really get good results though until I yanked the LSPV and the ABS unit. My brakes are fantastic now, I almost afraid to bleed them again in a couple of years lest I just happened to catch lightning in a bottle this time around.
I do have the e copy and a hard copy of fsm. So. I’m looking for the layman’s terms or anything other than what the engineer wrote. Yes it’s good info, but I’m looking for hints tips and tricks when I ask questions.
Yep so I am typing on phone and right before falling asleep so was just trying to get all the things on my mind write in here before I forgot. I didn’t wanna start a buncha threads, preferrered everything in one place.
So. The get the engine to tdc 1 what do I rotate? And will it hurt if I rotAte the wrong direction? I assume they mean turning the pulley/hub whatever it’s called that the fan mounts too?
I didn’t pull the timing mark cover wherever that is, as I couldn’t figure out where it was from the fsm pic. So what I am hearing from folks is it sounds like you adjust em hot. So procedure goes: reassemble everything, get it started and warmed up, then adjust valves, then pull air box back out of way to drop valve cover back on?
I am not sure if this is an language barrier or if you are typing on your phone or what, but please go back and edit your original post and take a little time and effort to make it readable. If you are going to come in and ask for help, don't also ask us to guess what you are trying to say. There are a lot of people on here that take the time and put in effort to help people, so please take the same amount of time when asking your questions.
Oh I hear ya, not trying to waste folks time, but I’m new to working/caring about cars so I’m feeling silly for asking newbie questions.
Another prob is the password for site is saved to my phone, but I don’t remember it. The password forgot link on here give you your password or just a reset link? I haaaaaate changing passwords.
Also the site doesn’t tell on my Mac, all the ads. You guys run a blocker or something?
