Brazing is great for that. I have used it that way a couple times on some hard top corners. I think this is a totally under utilized option. I cleaned up the rust first, then brazed in some pitting, then filed it down.
Really nice work. Like that the tranny hump has the sound proofing still on it.
Sarge - thanks a lot for postings - I actually thought about doing that early on and got off track probably trying to avoid a trip to the hardware store for screws. You/Kiwi got me back on track. I've now got 4 main small welded plates underneath with nuts and everything else taps into the frame. Much easier to take everything apart too, compared to my over-thought welded stud idea.
Jim - I've always liked those chatterproof type countersinks with the hole, but I've only got 1 old, small guy and it's 100*. So I'm using my old (dull) 82s, hand-held - would go a little easier on a Bridgeport
View attachment 1053156 View attachment 1053157 View attachment 1053158
finallyThanks V V, trying to keep anything that doesn't need to come off (for repairs) original. Reproducing the original patterns for the replacement sound proofing is a bit of a challenge. This Evercoat stuff seems a good match though, thickness and the way it acts. Does not cut easily with a utility knife but big scissors work well. Heat gun seems to work. Don't try to use a hole punch, it breaks in long cracks.
went to the Evercoat site. Which product did you use?Going to try to use this stuff to replace the original sound proofing stuff on the floor. Seems like the same thickness and material. Might try a heat gun, etc. and maybe a crude wooden form to press it down? Anyone have pictures of an original 78 floor?
