Bumper Surgery
Kansastitty
A couple of months ago I bought one of Jeremy's bumpers....that was about a month before I decided I needed a winch. Jeremy generously offered to exchange the one I have for one built for an 8274, but with shipping....well.
Anyway the project has been hanging over my head until today and I finallyt got busy. Jeremy used 3/4" solid rod as a spacer to keep the bolts from crushing the tube, but I do not have any way to drill a 3/4" hole, so I made some spacers out of 3/4" water pipe. I could only weld on one side, so I'l have to seal around the bolts to keep water out.
All I had was a cutoff wheel and a saber saw, so it took a little time. Just need to box in the opening and weld a plate with gussets on top......
And if you use galvanized pipe, remove all the galvanizing BEFORE you weld. Then as you strike an arc, remember that you forgot that it is galvanized in the INSIDE, too.:doh: :doh: :doh:
Sweet!
Good workmanship, (they trained you well in dental school ;p), but what you need a winch for, you haven't even wheeled your piece of art. :flipoff2: Shoulda come to Moab this year and test it out first :doh:, you are missing out on all the fun :grinpimp:
Give a guy a break here! I'm gettin' there! Look right beneath my name.....
I am not pretentious. Going West this summer. Late July or early August. I wanna visit, or meet some of these Mudders. I'll wheel it, kinda.;)
Are you and Michael coming to Asher's? Hope so.
Ed
Ran out of gas on Sunday so I got stalled out. Finished the box today. I hope HawkDriver is not pissed about what I did to his gorgeous, heavy bumper.
Thanks! Now I have a question....the primered bumper is presumably a Warn bumper and the plate on the back(maybe that is the only thing Warn about it) is wider to the passenger side. Is that to protect the winch? I kinda want to go "minimalist" on the mounting for the top two holes and was thinking about a couple of 1/4" uprights with gussets instead of a plate. I guess I really don't know much about winches, or wenches, for that matter.
What thinks you?:confused:
if you look at an 8274 they have the gearbox on the pass side. Most winches of that style are also a tad on the pass side to clear the steering box.
Erik,
The winch drum is centered, but that plate does not need to be much wider than the mounting holes. I was just wondering why the plate stuck out so far to the pass side. It is not tall enough to protect the motor, but maybe it is to shield the brake assembly, especially the ratchet plate.
Ed
