- Joined
- Oct 30, 2005
- Threads
- 4
- Messages
- 23
- Thread starter
- #21
It's not quite over...
Hey guys,
As per my previous post, we discovered that it was bad fuel (gasoline instead of diesel), however I now believe that I have some kind of engine damage as I'm getting a loud knock-knock-knocking.
So... we drained the tank of about 10gal of diesel/gasoline mix: thanks for the disposal suggestions, I'll see if the local FD will take it away from the Toyota dealership.
We installed a new fuel filter and we purged all the air which took alot of a lot of priming pump pumping and then cracking the injector feed tubes when we finally got it to idle. We managed to get all the bad fuel out of the lines, and we managed to get the beast to run!
BUT... now I have a horrible knocking noise and I fear that running on this gasoline/diesel mixture has led to serious internal engine damage. Opinons: do you think the higher explosive pop of gasoline would kill a 3B driving from Roseburg (farther than Canyonville!) all the way to Sunny Valley? What possible failures could have resulted from running on a gasoline/diesel mixture for nearly 40miles?
Do diesel and gasoline mix freely? or do they seperate out into two seperate liquids floating on one another?
What should I do next? The engine is clearly not a runner, and will not make it either to home (vancouver) or Baja. Yes, I should probably go on a Jetboat ride to take my mind off of the truck, but I would just rather go surfing in Baja.
1) Replace Engine: um... Steve T. how much did you want for a 3B engine?
2) Find a diesel mechanic to disassemble and fix problem(s) as a result of running on gas.
3) Buy another American Cruiser and tow mine home after driving down to the baja to go an surf and take my mind of of the truck.
As usual, I hope I'm keeping you guys all entertained, thanks for you input.
I'm now stuck in the Windmill Inn in Roseburg. We decided that we should take this issue up with the Shell station in Roseburg that gave us the incorrect fuel, we'll go and see how the cards play out tomorrow.
Call me if you have any great suggestions or ideas (541)-673-0901 rm 108
Regards,
Sean Allan & Ros Boyce
Hey guys,
Regards,
