I recently went through my braking system and there are the items I would address. I also run 33” tyres:
1. Replace front pads with factory pads
2. Sand rotors first and see if this gets rid of the pulsing. Warped rotors symptoms many times are actually incomplete pad deposition on the braking surface of the rotors.
3. Baseline the rear drums, pistons and ensure factory setup is per the FSM.
4. Confirm LSPV is adjusted correctly.
As others have stated, upgrading calipers is not required and might in fact be masking other issues with the braking system.
Once this is complete and nothing is out of spec, your braking performance should easily lock up your wheels at speeds less that 40kph. Above that I can threshold brake my 75 easily and actually overpowering the system reduces stopping power. I also went with the 80 series booster and clevis from
@cruisermatt and this made a nice difference to the pedal modulation. Clevis pictured below which extends the rod for proper pedal height. Not sure if this is required for your truck but wanted to include this in case.
