brake pad eating machine!
I know it is well documented but WOW! these things eat front brake pads like MAD!!!. I put new OEM pads, rotors and rebuilt the calipers with OEM kits back in Dec. The other day I got one or two little squeaks then a nasty grinding at low speeds. The nearest dealer is over 100 miles from me. Luckily I was in that town when I first noticed a little grinding at low speeds, well crap. I immediately grabbed a set of OEM pads at the local dealership and installed them in the Wal-Mart parking lot. One of my pads was already down to the metal and put a nice grove in my brand new rotor. Well that sucks! Moral of the story, check your front pads! I never really noticed any real sound from the "wear indicators" . So I would suggest just keeping a spare set of pads around and checking them OFTEN.
I actually drive the thing really easy and slow. But I did do about 15-17,000 miles in the last 8 months. Also I am living in the mountains so maybe all the mountain passes were hard on the pads. But usually I am moving really slow both up and down them. Hopefully this will be a reminder to keep a eye on the front pads.
I did the same thing. Now I carry a extra set. I'm using some ceramic pads from Autozone that seem to last longer and with the lifetime guarantee I get free pads from now to eternity.
Did you install the 80 or 100 series pad? The 100 series pad should last longer and I have longer life with EBC green pad too.
Me thinks OEM front brakes/pads get a bad wrap because guys lift their 80 and do not address the LSVP properly. For me the proper adjustment for the LSVP was full on:flipoff2: I have no problem with braking on 35's or premature brake pad wear.
Yeah, the LSPV should be adjusted (search should find you options). It's not just about front pad wear, it's also about safe braking by having the rear brakes do some work too to keep the vehicle stable during an emergency situation.
cheers,
george.
Not sure of the specs on your truck but in my case ('92 w/ drums in the rear). Once I serviced my rear brakes (drums) I seem to get more wear from from front pads. I did have to adjust the drums according to suggestions on this board. I am sure now that I have said this my son will tell me that something is grinding in the front...
You all need to get 3FE powered 80s like Jake and I. When I want to stop I just let off the gas. :flipoff2:
That will definitely make a difference...
How many miles have you driven in 9 months? With only one pad worn that points to a frozen piston in the caliper.
I had about 15-17,000 miles on them. The pads actually were very nice and even, but one was just a hair more and touching metal. They were all right about to.
I have read some of the write ups, But when you say full on do you mean the valve body moved all the way down?
Arm is all the way up. You cannot get enough adjustment just by dropping the LSVP alone.
Testing first is easy -
Disconnect the arm from the axle end and tie it all the way up and test drive. If you experience is like most others it will not be attached to the axle again. I do not have ABS and without any problems all 4 35's can be locked up.
Second on LCP. I am running 35s, not as heavy as Phil but I have 20k plus miles on them and still have significant pad left, near 50%. I am running 100 series autozone ceramic front pads though...
FWIW, I get 55-60k on my stock OEM pads in my 3FE.
Hey now are you saying my 80 fat!:mad:
My 80 is not heavy at all giving the set up, 6000lbs wet.
Well, you ARE heavier than me! ;)
Everything looks thinner when wet! :rolleyes:
Easiest thing to me was just to take a piece of aluminum strap and cut it just longer than the lift height and bolt it in as a spacer between the axle and the arm on the LSPV. If you have 3" lift you can't slide the LSPV down that far but you can just move the point that it bolts to up so its in the same position relative to stock and you retain its function and get your rear braking.
You also can't drive a cruiser like a Tercel guys, I see SUV's with the black front rims from brake dust screeching up to lights all the time.
Have you tried shifting down and using compression braking? Easy to get a 10-20% decrease in brake pedal use. Been doing if for 5 years/ 75000 miles with no other problems. The 80 series 1fz seems to have much better compression braking that many similar domestic rigs.
