Brake bleeding issues 201
Rainman
Wondering what my next vehicle will be...
Nashville, Tennessee
No novice here, but stumped just the same.
i'm working on a completely replaced brake system.
New master (No miles but installed several years ago.)
New lines
New wheel cylinders
New calipers
New pads
New shoes
I'm a veteran brake line bleeder and have never had to bleed a system more than two times. This truck has something up it's sleeve I can't figure. I've bench bled twice... Once after the 1st time. Once after the 5th time. I have now bled the system 7 times. Yes, I feel like I'm pushing against an immovable object.
Anyone have an idea what I'm forgetting? I'm using a clear tube while bleeding to view any air escaping and I haven't seen any new air in the last several tries. WHAT am I missing?
No pressure buildup.
After each bleed session. The pedal doesn't get any stiffer or build pressure up after multiple pumps.
I just went through this with my truck. I finished a knuckle rebuild and figured it would be a good time to replace my calipers (and pads and rotors etc.) as the rubber boots were torn and tired. Brakes worked fine before I started bear in mind.
Finished the knuckle rebuild, installed the new brake stuff and went to bleed brakes- cant' build pressure. Bleed 5 more times- can't build pressure. Same symptoms as you- no air bubbles coming out at any of the bleeders, no leaks anywhere, fluid in the master at the exact same level even after sitting for a week.
Long story short I replaced the master and all is well again. It seems it was leaking internally so no fluid was lost but it was not functioning properly all the same. I would think if your master bench bled successfully that might now be the culprit but it may be worth trying another.
The only other thing I can think if is rear shoes not tight enough.
Hmmm. The MC is brand new. Scott put that on when he had it. So it may be a year or so old but is new. And yes, as I stated in the 1st post. I did bench bleed the MC twice. Second time gave me one big bubble from the rear line. I'm having to use the one big rear reservoir type MC due to the booster taking up so much room on the disc conversion on this '70 model. That shouldn't make any difference though. I'll verify the MC condition with Scott.
How is shoe adjustment in rear? If no air is coming out and solid stream of fluid out of every corner, then perhaps rear shoes need to be expanded? If new shoes, expand to lock wheel, then back off 5 clicks. For used/worn shoes, I do about 3 clicks/ and feel drag and adjust as needed.
I recently had a 'similar' issue. After cleaning and readjusting rear drums and a fresh bleed, pedal feels excellent.
Pedal adjustment set according to FSM as well?
Also since you have disc front, drum rear....are you running the proportioning valve? Shouldn't affect bleeding, moreso just curious.
Okay. The front conversion was done several years ago by a PO. Never driven. I replaced everything beyond the MC which is only about a year or so old... Never driven. It's a later model single reservoir unit.
Now. I just went out and adjusted the rear shoes. THAT should make a big difference. Well, I've only jumped in and pressed the pedal a few times or so... Not a big noticeable difference. The carb is out for a rebuild so I can't crank it. It still won't build pressure with multiple pumps.
Might be able to get the carb rebuilt on Monday. SO mid week should prove one way or another. Thanks for the extra thought processes. I'll report what happens in a few days.
By "never driven", do you mean by you? Or this was an in-process fixer upper that hasn't been on the street when you got to it? The later model single reservoir sounds like it should be set up for front disc, rear drum. Do you think the PO adjusted (or knew to adjust) the booster rod depth? Maybe you're getting a full stroke on the bench bleed but not from the pedal.
A little history.
The truck was owned by a retired Military man. He had it repainted, pulled the gas tank out, put a front disc front end under it, poorly tried to put a booster and MC in it and peeled the plenum open for clearance... In other words, he messed around with it and gave up. Oh, he also paid Toyota to rebuild the engine. So it was down for a couple of years. Then my friend bought it. He paid me to do some work to help get it running but we never finished. The I bought it and began the ground up redo. So the truck had not been driven for about 3 or 4 years. I've had it for 8 months.
The truck is completely together (other than the carb rebuild in progress) with all new brake parts. I expect more firm pedal resistance still as is but I'll reassess after I get it running again next week.
May try loosening the nuts that hold the master, enough so there is ~1/8" gap between it and the booster, see if that has any effect?
I would invest in a one time Use of one of These :
Booster Push rod To Master Piston Guage
Your symptoms sound like it might be out as in to much of a Gap ?
SOR sells a white plastic one and AMAZON does too for the one time user , this OTC Dealership SST cost ,me close
well over $200+ , But has the Precision of a H55F as well ...............
I heard that you should place the reservoir on top of the leaf springs so that when the bleeder tube is connected, it can loop higher than the wheel cylinder, capturing bubbles in what is bled rather than in the wheel cylinders themselves. It seems to work well for me, so far.
Or... Just hold the first few inches of the tube up a little above the bleeder while you open it and it does the same thing. You can see the bubbles (if any come out) and it holds a couple of inches of fluid right there. Then when done, lower it, remove the tube and the rest runs into the collector jar. No mess.
The jury suggests plunger adjustment issues now. I'll see if I can get to that this weekend. We're narrowing the "potential problem" gap.
I had an evil time getting my rear brakes to work on my '78 and discovered that the shoe adjustment must be very tight to get the correct pedal travel. I was timid about adjusting the shoes out, and wasted a lot of time. I would now adjust them until the rear drums won't turn, then back them off until the drums turn and scrape just a little during a revolution.
I had the same problem on a Honda ATV - system was fully bled out, but shoes were out of adjustment. You'd think I would learn.
The MC clearance depth changes around 1990 on both minitruck & cruiser. When the common AL master off 80 or 4R is installed on a 1970's booster, the MC pushrod length usually needs significant adjustment, sometimes requiring running in the adjustment and shortening the pushrod with a grinder.
