You can isolate the problem by process of elimination - clamp off rear axle brake hose and the x2 front hoses. If brake pedal sinks, master cylinder. If brake pedal becomes hard as a rock, start unclamping hoses 1 at a time until you find the culprit.
PS here how to properly adjust drum brakes, stolen from a Facebook group:
What you need to do, each wheel. Adjust each cylinder up until you can’t adjust it any further (forget about spinning the wheel on the car as a guide), move the car forward and backwards and jam the brakes on hard each way. This will centre the shoes up in the drum. You find after you do that you’ll be able to adjust each cylinder a little bit more, do that then move it forward and back and jam the brakes again. Now jack up that wheel and you’ll most likely find you can turn it but it’s tight, just back each cylinder of one tooth at a time, alternating between each one until you can turn the wheel not quite freely but almost. Repeat for each wheel.
