Of the above, I have one answer. Removing the wood junk is easy with a heat gun. I have taken some of mine off. I keep saying that it can all go, but I am too busy. Just heat it up with the heat gun and peel it off. Then clean up the remaining adhesive the same way.
Harbor Freight sells a heat gun for 19.99, or less if it is on sale, which it usually is at $9.99-12.99. Heat it up and clean it off with a stiff putty knife that is not very sharp. A heat gun is really just a big-time hair dryer. It works the same but makes enough heat to give you an afro. Don't use it on your thinning hair!
Plus I don't see spending $60 on a switch or a cup holder! But I would spend it on the cup holder before the damn switch with the right logo on it. Just stick a smiley face on it and you will know what it's for! It doesn't light up so no point having the right switch....
