My mounts are newer, been on for a few years
That could be. Keep in mind I was running the downpipe for awhile for the blankets arrived. When I removed my DP I did mark the location of mount clamp. In hindsight I may have taken that action for granted in my install video because I knew where the clamp was going to be so I made sure to “nudge” the blanket in that direction.
I haven’t installed my downpipe blanket yet, but it does seem that a tutorial or tips for install would be beneficial possibly.
As soon as I’m done with my hydro-booster conversion, I’m planning on tackling this.
Hopefully will have my booster & MC by this weekend for install. Then I’ll probably start on the blanket install.
My Neutral safety switch fried as in melted and now I have to patch harness and get a new plug. Found pieces in classifieds and should be on the way tomorrow if all goes right. I'm sure I can find something else to fix before it leaves shop. I'll post up when I start it.Well it's all together and ready to go but.......My Neutral safety switch fried as in melted and now I have to patch harness and get a new plug. Found pieces in classifieds and should be on the way tomorrow if all goes right. I'm sure I can find something else to fix before it leaves shop. I'll post up when I start it.
Curious about your catch can - if thats what is above the timing belt tensioner there.
Wouldnt you want to run the PCV through that, not the other?
*NLXTACY is correct, oil past throttle body is OK, oil before compressor not. Also I do not have a oil consumption problem, not that worried about it. I can go 3000 miles with out adding any oil at all. Engine is totally leak freeCurious about your catch can - if thats what is above the timing belt tensioner there.
Didn't think about that! Almost makes two catch cans make sense, or one with two ports?Looks like he doesn't want any oil film in the turbo's compressor
I've not seen any oil remnants in that line on my motor, the PCV however always is soaked. Wonder how much oil actually runs through there.
Curious how much you catch.
Are you running one on that line as well?after 4000ish miles it’s just an oily film. Not even enough to puddle into droplets
Did you just unhook it/pull dist wire/crank til oil came out of the feed?Very first time just poured oil in from bottle. Huge mistake because I figured the cavity would be larger and it leaked inside the blanket and smoked for a week.
Every time after that I used a Syringe (removed needle) to just squirt some in. I also turned the truck over about a dozen times to make sure I got oil coming out of the feed hose.
If you are going to use a catch can (oil/air seperator) I would get a dual port can or Y the vent and PCV together.
Seems like a good way to make sure you're getting oil at the turbo.
I've also done a quick prime by pulling ignition relay and cranking for 5 sec or so about 10-15 times (taking breaks to let starter cool).
Lets oil pressure build before the turbo actually spools. Syringe is the right way to do it, but don't have one. Time to get creative.
