Thinking about a vanity plate in Ohio.
WETRBO.
What is a WET RBO?
WETRBO.
If you have to ask... you can't afford itWhat is a WET RBO?
I'd bet the same. I almost went new shortblock but rebuilt/machined mine instead. Should have gone for broke and built it all out with forged bits of fun.
What is a WET RBO?
Mmmmm, forced bits, yah mine will have those or I would have ordered a short block long ago.
One more for today. I’ve been getting a LOT of requests for headgasket kits because of the turbo coming out. Had a kit put together that put everything needed together. So it’s the typical valve grind kit and headgasket but it’s also the exhaust hardware and oil cooler gaskets.
Initially I was trying to put together a kit with ARP studs and Cometic gasket BUT not only did ARP not want to make Wits’ End a dealer but they are out of stock on the correct bolts. Summit has a few kits left.
As to Cometic, unfortunately the thickness of the gasket all depends on the amount of decking on the block and surfacing on the head. So I figured I’d just offer up the standard head gasket kit.
80 Series 1FZ Complete Head Gasket Kit
80 Series 1FZ Complete Head Gasket Kit (HGK-1FZ)absolute-wits-end.com
Which pistons are you going with? Are you going straight for +1?
Is forced bits when you let Bubba loose on the cruiser with a plumbers tool kit?
I have not decided yet. Plan to pick up the parts truck this weekend and start pulling the drivetrain. Engine going to Bill Lee for the rebuild.
Ugh, just heard back from the emissions lab.![]()
A big chunk of the oil supply hoses are done. The oil drain hoses will be done early next week.
View attachment 1995506View attachment 1995507
