Have you ran against a 5.7 petrol 200??? Id wager id roll youX2 - Mine drags off 200 series all day every day.
37s are incredibly tempting, but if im honest with myself I can do everything I do with 35s. I was more curious though in the context of turbo. I think there's an argument to be made on both sides that the higher RPM's with 35s/4.88s would be either good/bad on a turbo'd truck.Only too much if you run 80+ MPH often IMHO. You'll like the extra control offroad. But if you do 4.88's and don't like it the easy solution is 37's![]()
Keen to give it a go, however a petrol (gas) 200 is a rare thing over here and they get the 1UR-FE which is a 4.6. The LX570 gets the 3UR but never landed beside either at the traffic lightsHave you ran against a 5.7 petrol 200??? Id wager id roll you
Have no interest in signing up for instagram and you can't see anything there unless you create an account. Do I have that correct, or is there someway to see that stuff without signing up? Would like to see the latest updates, but refuse to create any more social media accounts.
No account needed, just click the link and stay as long as you wantThis is true, but you miss out on all the @Aloha Jen banned content![]()
Having run a 60mm BW turbo, my opinion is that 4.88 would only make the turbo that much better. It should help you reach boost quicker so that you have the opportunity to actually use a little bit of boost for around town type driving without having to floor it. Of course, the main reason I wanted the turbo was for highway driving. And in that sense, re-gear is totally unnecessary. But if you're digging into the diffs and spending the money anyway, I would go with the conventional 4.88 personally.What's everyone's thoughts on gearing? Having my diffs set up in the next few months. I am going to be running 35's, the obvious choice is to pair with 4.88's but if I plan to turbo will that be too much over gearing? Should I consider 4.56 instead?
Was my thinking as well. The easier to be in boost, the better.Having run a 60mm BW turbo, my opinion is that 4.88 would only make the turbo that much better. It should help you reach boost quicker so that you have the opportunity to actually use a little bit of boost for around town type driving without having to floor it. Of course, the main reason I wanted the turbo was for highway driving. And in that sense, re-gear is totally unnecessary. But if you're digging into the diffs and spending the money anyway, I would go with the conventional 4.88 personally.
Mad jelly.@NLXTACY - Turbo purchase made
But think of the AWD burn outs! That is why we're all doing this anyway, right?On that note we need the dyno graphs and see where the power and torque kick in vs stock. @NLXTACY I don’t need nor want WOT hero performance numbers
I'm running 4.56s/315s and live/play at 5,000' and above. Vehicle weight is 7,000 lbs.
You, my friend, have the patience of a saint!
..........and in desperately need of a turbo!![]()
I don't think AWD burnouts are going to be in the cards for users of this kitUnless you do a LOT of end-user adjustment.
No need for a lot of end-user adjustment!
I’m thinking Prius tires at all four corners inflated to 95psi on a slightly uphill wet road in 10 degree weather should do the trick.![]()
