bodylift pitfalls?
i know i know just lift it suspension wise etc...
i have a screaming deal on a bodylift for my 40, and it's a good idea for me, as i can fit 35's but they get torn up on the cut guards under compression... body lift would be equivelent of extending bump stops without sacrificing up travel.... anyway
what pitfalls are 40 specific for a 2 inch body lift?
what do you do about the steering column?
are shifters ok stock?
what needs extending (brake lines although i believe their solid along the chassis) clutch line?
what else?
I havent body lifted a 40, but I did do one on a 1st generation 4Runner. I did a 3 inch and the steering had enough slip in it to work, even when it was flexed up.
The shifters sat really low in the tranny hump, the tranny shifter fit okay, but for the tcase shifter, I had to trim the floor to engage 4low. Like the other post said, I think your only hangups will be the bib and fender mounts, I guess you could make blocks out of 2" square stock to make up the difference. Im no expert, just trying to help. Hodag
I body lifted mine to fit the Rockbox. 2-1/2" blocks I believe, cut out of 2-1/2 x 2-1/2 material. Double check it though by measuring the distance between bolt holes on the fender mount bracket. You will obviously need new bolts for around the body, but keep the rubber thingies. The bottom holes on the fenders come out perfect. Then just cut a piece of angle, weld it to the frame, and drill it out for the top holes on the flare mount. The bib gets the same block only 3" long. My steering wasn't a prob for me since I changed out the column and did the sagi. conversion. My shifters also weren't a problem because of the 465/RB/T-case conversion I did as well. The brake lines, stretch out the coils enough to accomodate the new distance. The clutch line fits perfect, there's enough length in the line to accomodate too. Sorry, I was only partially helpfull :cheers: . Make sure to loosen the wiring up though, then re-fasten it once you're done.
Campy
thanks...
my main concern is stock non power steering steering column = no slip joint... obviously people have done this, but i'm planning on doing it myself and have to get it driveable...
bib, sidesteps (mine are bolted to the chassis) and fenders were a concern of mine too.
what did you use to jack up the body?
everything campy said sounds cool . i run a 1 inch 4+ plus bodylift with a block to make it a 3 inch
also use sm465 and saginaw no issues here . but i like the idea about welding angle iron to the top of the frame for the fender to bolt to . and on another cruiser with stock steering used ross stewarts
(advanced handling ) idea of a spacer block and longer metric bolts under the steering box . and loosended the bolts at the firewall and lowered the steering column abit
any pics of hte advanced handling spacer? i can't find it searching or on the web
first pick is the 1 inch body lift bolted to a 2x2 block to total 3 inch bodylift ,
second pick is the spacer came in a kit with longer metrics and 2 inch body blocks . just unbolt steering box . pull out studs .slip spacer in between steering box and mount, screw in longer metric bolts . kinda mickey mouse way of doing it but it works . have to ajust the tie rod from steering box abit to get the steering wheel back to center again
bad_religion_au said:
thanks...
Sidesteps? Not to sure on those. The wife & kid learned quickly to climb on the tires to get in. Afterall, it sits 33" high to the bottom of the rocker panel :eek:
Hi-lift it. Start at the back, set the first couple of blocks, then work around to each side.
