Damn good amount of work done last night and today. Last night:
- Finished PHH and did the little hose that goes from the throttle body to the head. That one I think was worse than the PHH. Used ABA 316ss clamps for those connections.
- Removed and replaced the hose adapter that goes from the above the water pump up to the head. This was the original part, and was basically fused aluminum to aluminum. Removed finally by using Vice Grips and prodigious amounts of pulling. This also meant sending little shards of crap down into the water pump body. I cleaned out the bore, using a metal pick to get at all the plaque-y crap at the bottom, then removed my recently installed new water pump to recover the shards and plaque. Reinstalled and retorqued.
Today:
- Finished the rest of the hoses at the back of the engine compartment, installing all hoses with either OEM for formed hoses, Gates green stripe for straight 5/8 runs, and white stripe for 1/2 inch connections to the rear heater. Ordered the radiator hose set, little heater hose set formed heater hose kit, PHH kit, and crank seal / oil pump cover / oil level sensor / dizzy gasket from Wits’ End
@NLXTACY. Joey is a stand-up guy, highly recommended!
- Removed and replaced the gasket on the bypass that runs from the water pump over to the back firewall. There is a small metal gasket under there that someone previously used RTV or FIPG on, so got to scrape that junk off carefully with a razor blade before installing.
- Removed harmonic balancer using OTRAMM tool, installed new front crank seal and new oil pump cover gasket. The oil pump cover gasket screws were a royal pain, I stripped out the first one I tried using the #3 Phillips. Resorted to using the 1/2” MAC Tools impact on low air pressure, and 3 different reducers to get down to 1/4” drive. This finally worked but was touch and go and I still spun out a couple of the old screws. Bottom line - get a compact cordless impact for this job. Torqued down the new screws until I felt like the hex bolts would start to strip, then backed off. I didn’t find a torque spec for this, so just used the gutentite measurement.
- Oil pressure sensor gasket replaced. The original was so brittle it shattered into many pieces pulling it off. New one went on nicely. Good to have that done and should clear up one of the leaks on the side of the oil pan.
- New oil relief valve, oil relief spring, and gasket. This was the cause of a smallish leak as well.
- New OEM pulleys and belts installed, tensioned to 110 ft-lbs for the A/C belt and about 100 for the alternator. These will loosen up after running for 5 minutes per the FSM, will recheck and adjust accordingly.
- Reinstalled all radiator hoses and new TYC radiator, again with ABA 316ss clamps and with a very degreased SS coolant elbow. Looks great from underneath!
- Reinstalled harmonic balancer torqued to 300+ ft-lbs. The biggest torque wrench for rent at O’Reilly goes up to 300, so just used that plus a little extra bean to call it good.
- Reinstalled the headlights, signal lights, and grille
- Reinstalled battery box and battery
All that’s left is the rear heater lines (need to clean, paint, and reinstall some new soft lines while waiting for clamps) and the really easy to get to little heater bypass at the front of the motor. I’m planning to run distilled first, then drain, then refill with 50/50 green and go!
Some photos, was busy literally from 8am to 5:30pm:
OTRAMM tool
@OTRAMM ready to go:
What it took to get the stupid screws out. Don’t do this at home, get a real compact wrench:
After. Missing a few things but looking good:
Just about everything in here was touched - thermostat, water pump, bypass, gaskets, hoses, etc:
New alternator pulley. This stupid thing is $60 new.
