Build Biscuit is (still) Keeping The FJ40 - Customization/Improvement Thread
Next up to address is the clutch.
It's slipping under moderate or heavy acceleration. The clutch disc is at least 20 years old. Currently I have the three-finger 3speed clutch with the 3-speed flywheel in front of my H42 4-speed. (Coincidentally period correct for my 1974 had it come with the 4-speed). There is a good enough local shop, that I'm probably going to throw money at the problem. The big question is do I update to the later clutch or just replace the old-style three finger.
That will be followed shortly by rear brakes.
The existing drum brakes need work. Like the front, if I am going to put a bunch of new parts in, I don't want manually adjusted brakes. Options: Rear disc kit with the GM components (likely easiest). Though I have seen a thread with @cruisermatt FJ60 rear drum conversion (would require sorting out the parking brake to enable the self adjusting). This one I can do in my driveway. :wrench:
I still have some Aisin clutch kits for the older systems Mike. But know that the throwout bearing hubs are obsolete, and they are a high wear item.
I have put some of them aside to see how they take to welding up the divots, but haven’t gotten around to trying it yet. If you need one of those as well, lmk, and I will move that project up the list.
OTOH, if your wheeling days are over, changing to the newer design will net you a more highway friendly clutch. I just got one of those flywheels turned on Thursday 😉
Had a hunch on the clutch slipping and decided to check it out.
My clutch pedal has always been lower (closer to the sloped part of the floor) than the brake. I hadn't thought much of it. So I decide to go check the pedal height, play, and clutch fork play and compare them to the FSM.
Pedal had zero play. Height was far below spec. Spec is 215mm, this was probably closer to 180mm. (I didn't measure before).
Without adjusting the pedal, I checked the fork play. Also zero.
Started off with adjusting the pedal. FSM spec with the booster is 215mm pedal height and 0.5-3mm of play. With the clutch pedal at 215mm it was even with the brake pedal (shocking, I know). Play was now between 15mm and 20mm.
Now that I had play in the pedal, I went back under the truck and rechecked the play on the fork. 3mm, right on spec. (Better lucky than good in this case).
Now that the clutch hydraulics are fully releasing pressure, I took the 40 for few drives. First around the neighboor hood and the a longer one when it was warm. Clutch definitely is engaging much better.
Since the pedal still has a lot of excess play I can in the immediate short term, adjust the pedal back down until the play is in spec. But master cylinder probably needs to be rebuilt. I suspect the spring in there has been compressed for a very long time and isn't fully expanding.
I still need to drive the 40 in similar conditions to when I had the slip symptoms to see how it performs.
Are you running a return spring on the clutch fork? The piston in the slave needs to be seated all the way in the back of its bore. You might try bleeding the system. There's no reason to have 15-20mm of freeplay if measured correctly. I found the freeplay is when the piston/rod in the slave starts move. My slave is on the drivers side so i can look at the slave and push the pedal with my hand.
I do have the return spring. Replaced it and the bracket for it about a year ago along with the push rod. It's definitely seated all the way into the slave cylinder.
Is your 15 to 20mm measurement when you feel resistance in the pedsl because of the t/o bearing pushing against the pp? Not that it matters, the freeplay adjustment is to insure the master isnt pushing fluid with the pedal rest.
Mike, you need to have someone push down on the pedal while you carefully watch the clutch fork. The fork should pivot cleanly, like a tie rod end. Unfortunately it is not uncommon for the rivets that hold the spring steel pivot clip to the pivot to loosen up. Then the fork lifts off the pivot before actually moving the throwout bearing.
If this is the case, and the clip is not too loose, you can remove the fork and re-peen the rivets. Or you can replace them with an appropriate gauge of sheet metal screw.
I'll give that a look next weekend.
15mm to 20mm was for any resistance beyond the pedal return spring force. Felt like that is when the pedal push rod was engaging the master cylinder piston. Looking at the pedal pushrod I can adjust it maybe 5mm to have acceptable thread engagement left. Still far beyond spec.
Minor project this morning. Finally replaced the long bit of hose I had as the breather from the valve cover to the air cleaner with two 2F breather tubes. I couldn't get a good hose clamp over the air cleaner side, so reused what I had before.
And yes I fixed the cutoff solenoid to route on the driver side of the breather tube.
The fork seems to my eye to be pivoting cleanly. In the video the initial bit of the video the small motions are from me pushing against the pedal play.
(And yes I know I need to better secure the speedo cable, have a replacement on the shelf that's in the backlog to install.)
And of course I noticed a new oil drip on the driveway. :bang: Seems to be coming from the side cover area, but I'd need to clean the engine block to get a better idea where the source is to be sure.
My guess is I overtightened some of the screws way back the last time I touched it years ago and the more regular use has led to more oil find its way through where the cover is deformed and not sealing with the gasket.
I have been back to daily driving the 40 on the commute to the office. Part because I like it, and part to continue with my hunch on the clutch.
The slipping was only happening in the afternoons when it was hot and after being on the 55mph highway stretch. The weather this week matched that with 90+ degrees each afternoon.
I'm happy to report that the clutch isn't slipping. The pedal adjustment to (closer) to spec seems to have resolved the issue. I can now accelerate hard without any slipping, which along with the front discs, has immensely improved the drivability.
So replacing the clutch seems to be on hold until it is truly needed. Probably took some life out of it while it was misadjusted, but for now it's good.
While I gather parts for the rear disc brake conversion, I have started to think about the spare tire carrier.
When I got the new wheels and tires the backspacing of the new wheels prevented mounting the spare, even with a 1/4" spacer like I am running on the front. Issue was the sidewall contacting the plate style carrier.
While I could have fabbed up something, I bought a spare tire spacer for an FJ Cruiser (Toyota FJ Cruiser Spare Tire Spacer - https://warriorproducts.com/toyota-fj-cruiser-spare-tire-spacer-91635.html) that moved the tire out 2". This allowed me to mount the spare but had a side effect. While I can latch the tire carrier just fine, the increased moment arm for the tire prevents the upper bumper bolt from making contact with the rear door when closed.
It's stable enough on on-road to stay latched, but I know that once I'm off pavement it will bounce around and the hinges and latch will take those loads. Combine that with the latch and lower hinge being attached to a rusty sil, and it's only a matter of time before the current setup causes body damage.
This has me looking at the 4Plus tire carriers. I have wanted one for a while. But now the question is: do I get the tire carrier only or the double sided carrier?
Tire carrier only:
Pros:​
Much cheaper than the double sided​
Only need to open one thing to get in the back.​
Cons:​
If I need to carry fuel, need to figure it out. (Options exist​
Double sided carrier
Pros:​
Can carry fuel cans when needed.​
If I tow there is some limited improvement in force distribution across the entire rear cross member (not a lot, the 4 bolts in the middle still take almost all of it)​
Hides more of my rusty rear sil.​
Cons:​
Price. >3x the single side price.​
Need to deal with two swing arms all the time.​
Basket on second arm would be empty most of the time, probably.​
It would be awesome if there was a version with a removable arm for the for basket so I could run that only when needed.
Drag Link Refresh
Took today off of work and decided to tackle a small project to rebuild the drag link end where the pitman arm attaches. I had considered the famous "2 penny" mod, but bought a rebuild kit a while back.
Disassembly:
The screw on the back came out with only a mild amount of coaxing after a couple hours of letting the PB Blaster work its magic. The seat and spring came out easy with a wiggle of the wheel. I used a magnetic pickup tool to pull the cups out.
After wiping the grease off the outside of the drag link end, I noticed some wear. (Highlighted in red in the photo)
Comparing this to the picture on @Coolerman's website Drag Link - https://globalsoftware-inc.com/coolerman/fj40/21c.htm the wear is obvious.
Looks like a new drag link end is in my very near future.
I got the new drag link end installed.
Spec is to tighten the rear screw until seated and then back-off 1/2 turn. I'm trying to sort out what 'seated' means since there is a spring involved. Do I simply hand tighten (minimal spring compression) or do I tighten until the spring bottoms out?
Edit: made a dedicated tech post asking the question as search isn't returning an answer.
Seating to have the inner seats hand tight (not finger tight) seems good. Drag link is buttoned up.
Interesting notes. The replacement end had the port for the zerk clocked 90deg from the original. The zerk is now opposite the pitman arm. It clears the frame, so no issue there.
Replaced the thermostat today.
A month into fall the morning temperatures have dropped and the daytime temperatures here in Boulder are doing the usual range of anywhere between 45F and 80F. I've continued to drive the 40 several days a week and noticed with the cooler mornings it was very slow to warm up. Even 20min of driving would only move the need on the temperature gauge barely past the bottom mark. And with winter on the way I selfishly wanted full temperature coolant going through my heater.
This made me suspect that someone (younger me) had forgotten the inner gasket that sits between the top of the thermostat and the upper housing the last time the cooling system was open. Alternate hypothesis was the temperature sender wasn't working, but it seemed less likely. The radiator was just too cold after driving on highway.
After closing the isolation valves I put on the heater circuit, I drained 3/4 of a gallon of coolant out and disconnected the hoses to the housing. Thankfully younger me did put antisieze on the bolts so they came out without any issue.
Lifting the upper housing off and there was the thermostat, without any internal gasket. I checked the upper housing just to make sure it wasn't stuck in there, and it wasn't. It turns out 3/4 of a gallon was just barely enough as there was still coolant in the bottom half of the lower housing.
While the installed thermostat was probably still good, I suspected that it was a 160F thermostat and not a 180F. Having a 160F in southern California made sense, and the lack of a internal gasket wasn't notable. But here in Colorado, I went with a 180F thermostat.
I buttoned everything up with new gaskets, including the internal one, and torqued the housing bolts to 12 ft-lb. I have one of those fancy funnels for filling coolant that lets you run the engine and burp out any bubble. Started up the 40 and let it run while monitoring the temperature with an IR temperature gun. Thermostat was definitely working and the internal gasket was preventing bypass to the radiator.
I occasionally would pull hard on the bullbar to rock the 40 which helped get some bubbles out of the system. After idling for a while the temperature stabilize with the temperature gauge indicating ~160F (halfway between the bottom and first marking) which matched the IR gun temp at the sender.
I have a fluid heat riser that I was originally going to install today, but decided to not to. Routing of the hoses is going to be tricky to get around the throttle linkage, brake master cylinder, and the remote oil filter mount. (After my 1.5F grenaded in 2003, the replacement engine was a F from 1972) That project will take a bit more thinking and planning.
Remote is remote Mike. On the blue 45 the oil filter bracket was relocated to the backside of the fender skirt, which has a consequence of also having it much further away from the exhaust heat. 🤔
Should make plumbing the fluid heater a lot easier.😉
That is a very good point. Remote is remote, location (within reason) is flexible.
Mark, thanks for that. I had lost the forest for the trees (or in this case the engine bay for the oil filter.)
It's been a warm and dry winter here, so I have continued almost-daily-driving the 40. That of course gives time to find plenty of things that need to be fixed or adjusted.
This weekend I did some small things:
  • Adjusted the draglink since my steering wheel was off the to left a bit. Determined it was the drag link and not the steering wheel itself since from "center" I was slightly lopsided on how many turns it took to get to the stops.
  • Replaced the bulb in the left front side marker light. Turns out there was corosion on the bullet connector that was causing no power to get to the bulb. Cleaned that as best I could and have it working again.
  • Installed the fuse and relay brackets from @cruisermatt as a start on finally installing the headlight harness I have had for three years.
  • Tightened bolts on the hard top. Some had backed out a good ways, some were missing. Pretty much all were loose.
Other things I have noticed and need to fix:
  • The left side taillight has something odd going on when the running lights or brake lights are on and the hazards/left turn signals are on. I've noticed that when brakes lights are illuminated, I get just the slightest illumination of the left turn signal. And when the running lights are on and the turn signal flashes the break light dims. So it's probably a ground on that combination lamp. (It's always a ground.)
  • I get a rapid flashing on the right turn signal at the end of my commute home. Doesn't happen when I leave work, doesn't happen during the morning commute, only on the last right turn coming home. Probably a ground, but still very odd.
  • I need to order one of @lcwizard's tire carriers. The spacer I put on to fit my new wheels and tires moved the tire out far enough it shakes and causes the latch to come slightly undone, which leads to more vibration. And with the rust on the rear sil, it's probably only a matter of time before the stock tire decides to come off the body. I've used a voler strap to hold the latch closed as an interim fix, but it's not ideal.
    I have been going back and forth on the tire only carrier or the dual swing arm carrier, not that I would be carrying anything on non-tire side regularly. But part of me likes the idea of having a second swing arm.
  • A spot on the hood has managed to flake the paint off down to bare metal. No idea, but it went through the factory primer, factory paint, the primer and paint from 23 years ago when I repainted it.
I am also working on figuring out my approach for doing more involved maintenance, like the rear disc brakes upgrade. Not having a usable garage (it's 10' wide) for working on the 40, my driveway being very exposed, and no convenient way to get the truck into the back yard is making it tricky.
Did a small bit of wiring cleanup today while installing the positive cable from @Fourrunner's battery cable set.
I used heat shrink 3/8" ring terminal connectors on the connections to the fusable link (mine is a self resetting circuit breaker, story for a different time), the positive leads for the auxiliary fuse block, and battery tender positive lead.
The leads to the auxiliary fuse block were originally connected at the starter side of the battery cable, and had taken some heat damage during some repeated starting attempts years ago. I relocated those to connect at the battery side.
