Bilstein & Eibach vs. OME 2.5"
That's good to know. I currently have 5100's all around with Toytec 112-620's on front and Toytec Superflex up front. I like the ride but they only gave me like 1.6in on the front and I'm having issues getting the front raised to be level (2nd notch causes issues - not enough down travel) so my only other option is spacer.
I may be considering all new if the spacer doesn't work well.
No issues running on the second knotch with 112-620's and 5100, just NO higher. Should give you exactly 2.5 for the front. I had them for almost 2 years like that and was a great all around set up.
Interesting.. @co4wheel wheel on here recently bumped his up to the second notch and had issues. He said they were topping out on fireroad bumps but I expect he could elaborate further. What were you running on the rear at that time and what UCA's?
Bottoming out? Still OE UCA. Will be doing SPC here soon but its been working fine as is. I run 886OME up front now to compensate for ARB bull bar. Still running the same Icon rear spring.
Are the 886OME on first or second notch? I'll be adding SSO bumper and winch eventually.
It was topping out. Said another way it fully extends and makes a noise. You have a heavy bumper so it may not do it on your GX. Weight would bring the nose down a little and help.
