Probably give them another pass with the sander once there’s daylight again, hit the bottom of them with some paint, and bolt them in.
They looked better before you put them to the grinder???
True. I’ve got shoulder belts attached to the rear hoop, it’s just for where to attach the center receivers.Factory shoulder belts were either attached to the exhaust tube "roll bar" or the removable tin hard top, so just about anything is an improvement it seems to me. Either of your mounting choices for lap belts are probably strong enough to cut a person in half before they break.
It's a 40. Any real crash will have your noggin bouncing off enough steel it won't matter how well you're strapped in, the egg is getting scrambled![]()
Scout II P/S box and Saginaw Pump. The P/S will turn 33x10.50 BFGs on dry pavement with 1 finger (or the palm of hand) while at a standstill.Is that a bj60 power steering box? It probably would have been easier for me to go in that direction and delete my relay rod? Not drag link??? Now I’m confused.
My 33x12.5 bfg’s rub on the push pull steering and suck. Going to the main land to pick up some 33x10.5 soon. There’s only 3 of them so, two for the front and one for the spare. And only 150$ for 3 @ 75 percent. Older but kept in a garage for 10 years. What could possibly go wrong?
Yup... it's been a couple. Not sure how many exactly. I believe it was 2011 that I bought the pair of thirds... and about 2012 +/- that I swapped in the rear set.Do you finally have matching gears and 4x4 for the first time in how many years???
There’s tons of information online on boosting pressure and flow. I know and applied the basics when I built my pump… but it’s more or less stock. The boost is perfect. It doesn’t feel over boosted, turns with no effort, but lacks road feel. Just what I wanted.I installed a saginaw pump on my 3B Bj60 with 35's and welded front end. The stock toyota wasn't up for the task. The steering wheel feels way better too. Tracks better as well. The stock one was always over heating the fluid and blowing its load all over the place.
