Build Big Red Toy
Looks like I need a new input shaft. Hopefully that's all I need .
Might just go ahead with a full rebuild of the tranny and maybe a new clutch. Some bearings and the input shaft seem shot .
That sucks Mike. Do you rev match it on down shifts or use the clutch? I bet the breakage was caused from the bearing going out creating slop in the shaft, but I'm no expert with transmissions.
I typically use the clutch. I suspect the pilot bearing was the cause. I remember a couple of years ago it was a concern because I could have sworn that if I listened carefully I could kinda hear it. But since the 4bt was so loud I figured it was just paranoia. Will know more over the weekend.
I stopped by the Dodge dealership for the recommended gear oil. $22 a quart out the door with military discount, freaking monopolies. I think I'm just gonna go full retard, rebuild the tranny, replace the clutch possibly with a ceramic and the rear mean seal, motor mounts and replace the transfer case oil because I'm already in there. So question is what is everyone using for their transfer case oil?
Here's the "SPECIAL" gear oil
Newer vs old input shaft
Rehooked up the methanol injection pump and I'm getting 30psi way too easily.
I decided I'm adding a second turbo once I get back from deployment.
Nice purse :flipoff2:
Might as well rebuild while its out, especially if you have the means and know how to do it. Beats getting stuck somewhere if that metal from the input shaft decides to grenade your gearbox in the boonies.
I put down my kidney as a deposit. This is gonna hurt....:crybaby:
I might use the royal purple in the transfer case.
I just ordered a 13 in heavy duty clutch and a short shifter kit for the NV4500.
I can't Google this at work and my phone is turning up with no results and I'm bored.. .....
Anyone know how many quarts of oil the t case takes?
Debating between royal purple and lucas oil
Good updates, hope you get it all back together with no problems.
Freeze plugs are in. Hopefully all will be put back together by the end of the week , in time for some camping.
Entertaining the idea of a toyota hood scoop to keep the firewall cooler. But that's way down the line.
Transmission, clutch, transfer case, freeze plugs, motor mounts and new fuze box all back in with no real issues other than it took longer than I like. The clutch is a heavy duty 13 in clutch but the pedal feels like it's from my VW, softer than I'm used to on Big Red. The transfer case has new synthetic oil and the gerabox is rebuilt with new Dodge recommended oils as well.
The new motor mount are filled wih liquid and are less rigid than the old ones that tore. Apparently there are only two freeze plugs on my 4bt, one on the side and one in the rear. Happy to say there are no more oil leaks except for the seeping of the steering gearbox and the occasional drop from the blow by tube.
Here the is the torn old motor mount
New Motor mount.
and the new fuze box. It says it's marine grade, but clearly you can see it's not water proof.
My next big project is the compound turbo then maybe a paint job. But that's after i come back from deployment.
Did you pull the trans and TC yourself? Nice work.
No. someone I know had access to a lift and some tools. I wouldn't dream of doing this by myself at home.
