Or you could drill and tap your existing slidersThey are welded to accept air pressure.
Should I worry about internal rust from moisture?
Well, they are 3/16". Not sure exactly how long they would take to rust out.
is wearing heelsCould you seal the inside somehow? With tank sealer or something?
x2
one caveat: SROR's may be more rigid as Jim uses fully boxed tube, some of the tube on the MT sliders are C channel.
I never even thought about this. So if you were smart and trying to do things once, would you do a 3" exhaust upgrade before you got your sliders? Assuming you were going to upgrade that is.Maintenece issues such as changing exhaust system and getting to hard to reach lines would be another advantage to removable sliders.
Ditto, although its just IMO. The kickout at the rear is the selling point for me.I voted for the Metal Tech, that's what I'd buy if I had the money and didn't have the ability to make my own. Things I like more about it
1. Formed main section gives better cross section shape than standard square tubing.
2. Two stage rub rail.
3. Massive cat guard.
4. Mounts for extra batery or air tank
5. I just think they look cooler.
What a rock sees right before it’s crushed by a one piece ½” thick CAT guard:
I think bolt-on has better advantages when there is auto damage to the slider or truck frame. If in a collision, the slider or frame can be removed so it could be bent back into place. Maybe the slider would be cut off if it was in the way. Maintenece issues such as changing exhaust system and getting to hard to reach lines would be another advantage to removable sliders.
So I was just wondering if anyone has suggestions on the best way to protect that part of the exhaust pipe just aft of the cats.
