You guys are worrying me. I just received my Hanna Sliders at the end of last week and will be putting them on tomorrow morning. Does anybody have anything good to say about Hanna Quality Sliders.
Thanks for the ideas Doc. I'm not sure if I understand the first one though -- are you saying you just cut the exhaust pipe off after the cats and eliminated the back half of the system?
Well, they are 3/16". Not sure exactly how long they would take to rust out. If you use the air for ARB's I would put a filter somewhere to make sure you do not get particles into the lockers.
NO!!!!!!!
He is talking about fitting a 4x4Labs rear bumper. You have to cut off about 4" of the rear frame and about 3" or so from the resonator to fit it in.
In an older thread, Norcal Doug brought up a good point. Location might be a good guide to offset shipping costs: West coasters might look to Hanna, Thin air breathers look to Slee, east coast look to someone closer..
Very happy with the home made approach.
Nice job and clean design
What did you do for cat protection?
Bolting requires maintenence, depending upon the use.
Welding doesn't, at least not as much.
NO!!!!!!!
Actually, I cut the pipe about 8" behind the resonator to clear the frame rail, now if I land on the exhaust it won't pinch closed on the frame, it'll just push up out of the way and be protected by the frame rail.
yeah...but I think the original poster of that question was talking about where the exhaust sneaks under the frame rail just after the 2nd cat on the 95-97 models. The 93/94 with the side-by-side cats allow for the exhaust to be routed above the frame rail after the 2nd cat -- not so on the later year 80s.
To answer his question, there's not much you can do. You could build a skid for it...or add a 1" body lift to allow you to route the exhaust above that frame cross-member...or...cut a hole through it, weld in a 3" diameter section of pipe, then route your 2" exhaust through it.
or...you can just do what I do...bash the hell out of it and get it replaced from time to time...
