Best replacement radiator for the money today...
I received an email from RockAuto today notifying me Denso is in stock. I checked it's NOT in.
Every time I've called on one of these Denso to verify, it's not in stock.
BTW the Denso popped up on RockAuto for $154 (or around that). I ordered it and canceled my Jegs order.
I was actually going to by OEM tomorrow so saved me $$.
Let us know how that works out for you>
I purchased a Denso from Rock Auto as well. It was a direct fit with no mods needed. My temps have been the same as before the swap.
I had to replace my radiator about 2-3 months ago. I first went with OEM, but the first one I received leaked worse than the original one. The 2nd OEM replacement that was sent leaked as well in the exact same spot. Rather than just ordering a 3rd OEM replacement I went with a Denso from Partsgeek and had no issue at all. Plus, the Denso is way cheaper when compared to Toyota OEM. Far as I am concerned Denso is the way to go. That's .02
Ordered the Denso from Autoplicity through Amazon. $211 although now out of stock. Still showing as being delivered 9/15-9/20. We'll see...
Got my Denso in after ordering 2 weeks ago from amazon 3rd party shop (speedshopusa). Been waiting for all most 2 months for a Denso to be back in stock since my LC has been down from a coolant leak. Going to do the tbelt w/pump and Ts at the same time.
The plot thickens...
Yesterday, I received a shipping notification from Amazon, an order-delayed email from Autoplicity, and an order canceled/refunded email from Amazon.
So....I have not gotten the box but I think I scored a Denso. Set up an alert on Rock Auto and for the second time in a week it popped up.
I instantly put in my order. It was now $12 more than the week before but I got an email it is on its way to me.
So if you want a denso this is the way I scored one.
I should be at 200,000 miles in about six years so about the same time as you so your recommendation is a new radiator at the second timing belt water pump change sounds reasonable
I've been working on three rigs this summer. My 01LC 167K (overly maintained for past ~110k/13 years), 01LX 214K (minimally & improperly maintained) & 00LX 263K (under & improperly maintained). The color of each radiator plastic top was progressively a lighter brown with miles. The heater Tee's were also progressively a lighter brown, most notable driver side. The age was not that much different, and even thought these turned lighter brown from a nice clean black with more miles, I felt heat & improper maintenance had big effect as well.
-01LC radiator looks good. I did replace Tee's last week, they surprisingly looked good, best was PS I'll save it as a spare.
-01LX radiator looks ok but color is light brown, but has improved with plastic conditioner. I'll do tee's during next flush.
-00LX not only needed a radiator, Tee's fell apart when I touched them.
I've seen many reports of DS tee being in the worst condition. DS is hottest side, so for sure heat plays a big role in the plastics' condition.
I think not only miles but running hot, mixing coolants, not flushing at factory intervals and local environment (desert to artic) all play a big role. Early warring sign is color, but even that can be misleading if plastic conditioner has been used.
I'm thinking closer to 250K miles. But properly maintained and inspecting trumps miles in my book. Additionally one must be alert to that sweet smell of antifreeze. Once I smell that, I'm looking for any clues. First; has level gone down when cold (engine & ambient temp) Second; Toyota red trails' of pink flakes at any leak, just one more reason to use the Red in my book.
Can't wait to see what you get, let us know if it's the real deal!
It came from RockAuto. What pisses me off it looks like these are sitting somewhere since 2/10/2016 even a raft from Taiwan can get here in 6 months.
Anyway last piece to my puzzle. It will be a month or so before install but it looks correct.
