BEST H.E.I. Dist?
Quote:
Originally Posted by Yotahilux
Truck runs pretty good but I still wonder what would happen by adding an aftermarket coil that is hotter?
Chuck
Nothing would happen.
The coil doesn't determine how "hot" the spark is; plug gap, compression and air/fuel load do. "Hotter" or higher voltage spark doesn't mean more power or more burned fuel. A high voltage has a down side: insulation breakdown and unreliability. This is why the manufacturers only use the minimum voltage necessary to make a reliable spark. There is no up side to a hotter spark than necessary.
Wait a minute...
You forgot the "bling" factor of having the chrome coil with the fancy logo.
That alone probably boosts horsepower by 1-2%, as well as improving gas mileage...
Rocky
I spent the money on a GM HEI.
2 years later, I spent the money to go back to the stock distributor.
The HEI never ran right. It became hard to start.
Warm up took twice as long for some reason.
I had to wait at least 5 minutes to get it to warm up right.
Misfires caused fumes that made me sick.
I had to jiggle the cap to get it to start.
I replaced the coil, cap, wires and ignition module which did not help.
I saw no performance improvement or mpg increase.
The advance curve was not right for the 2F.
IMO stick with the stock distributor.
I no longer have any of the problems I had with the HEI.
there are lots of posts just like yours, some were even really unlucky and lost oil presure when the gear on the HEI bit the dust.......but I guess you could then install a chevy motor......and that would work with HEI just fine ;)
Toyota motor= toyota distributor=good
which is one of the reason i would like to know how those non-usa deallies are.
i have one tucked away somewhere, also have an hei in the 40 now. but i don't want to lose any performance;p
I have a "non-usa" distributor sold through SOR. It has points and works great. I know that the busingings are in good shape due to it's relatively short life so far. I have zero problems with it. Stone ax simple and easy to repair in the shop or out on the trial.
Good luck! :beer:
Not to confuse or second guess anyone here, but there are several articles written on this topic. Peterson's 4x4 magazine installed one several years back and had a better throttle response and a little better MPG vs. the old set up. Overall they liked it. In the past, HEI dist have caused problems because the gears are not a perfect match to the Toyota oil pump. You have to be extra careful when you go this route.
My opinion is "electronic ignition" is better than "points" and a bigger spark in the piston chamber is better. So a 79 dist from a fj40 would also work too but one from an fj60 is better, it has a bigger cap but you need to replace the side cover on block as Pimp mention. In your case a Toyota part would better fit your needs unless you want to do a string of mods.
Horitexan said:
Now I'm considering going with a HEI dist. in my 02/75 FJ40- for better performance and gass consumption. I'm looking hard at the D.U.I. HEI distributor, but a friend is pushing "MSD." What, in y'all's experience is the BEST H.E.I. distributor for a '75 FJ40 and WHY?
Where Can I find the best price for what you recommend?
Thanks for all of y'all's advice!
Nick
Austin, TX
Pin_Head said:
Search :flipoff2:
Sorry Steve, but I had to do that. Actually I think that Jim C posted the numbers or they are in his article about distributors in tech links.
Guess I should have prefaced my post with the fact that I have been....
How 'bout some #'s pal?
There is reasoning behind me asking for these….I really hope to further this conversation and learn more….
FJ40Jim said:
The typical dissy advance curve maxes out at 3600RPM. If the advance specs are known for the dissy, then it can be set at idle.
Example: A typical Cruiser dissy will have 20* mech advance and 10* vac advance. Total timing of 36-38* is good for a 1980-earlier 2F. If base timing is set at 8*, then 30* of total advance is brought in, max timing will be 38*.
Ok.
So,
Is there any advantage to more advance than a stock unit could provide?
Poser said:
Does anyone know the advance curve numbers of a stock, non-USA vac advance, or mechanical advance Toyota distributor?
Yes.
Oh, you want to know them?;p
E-1968 world spec dissy
mechanical:
900rpm advance begins
1800rpm 18*
3200rpm 30* All in
Vac:
4" adv begins
12" 16* all in
HTH
Poser said:
Ok.
So,
The answer is:
It depends.
There is an optimum timing curve for an engine. The optimum timing curve will give best efficiency at any RPM point. If the ignition is advanced or retarded from the optimum point, then the engine is not operating at best efficiency.
So, there may be an advantage to more advance.
Or there may be an advantage to less advance.
It's easy to figure out; just dyno the vehicle and adjust the timing in 2 degree increments, while holding other factors the same. If changing the timing improves torque everywhere, then the curve is good, the timing just needs reset to that point. If changing timing causes Tq to go up at some RPM but down at others, then the curve is not matched to engine demands.
Rinse, lather, repeat until engine runs strong at all RPM points.
Edit:
Now that you've sucked me into this bed of coals, here's a bucket of gasoline.
can you recurve a 79 dizy?
I have dicked around with all of these and installed and use them all into different 2F's. I have even seized (doh!) a couple 2F's doing it.. I have run:
- '79 factory dist with OEM ignititer/combo
- FJ60 dist with OEM igniter / combo
- Both of these with mini truck igniter / combo (smaller, less spark (probably) but nice little waterproof unit).
- All sorts of early-mid 70's vaccuum RETARD distributors with points
- A few '69 era aka "NON USA" early vaccuum advance distributor with octane adjusters.
- Prett much all of the different era points distributors (both vaccuum advance and retard) from '69-on with a Crane Cams (similar to pertronix setup) as well as all of them with OEM points, coil, and ballast resistor....
- And finally I tried to modify a HEI from OEM GM to Land Cruiser, basically what DUI does...
Conclusions are: Pin_head is right. We have also discussed this many times before mostly on PBB before mud became big.. It is not size of the spark, it is WHEN. I am not sure if a longer spark makes a difference or not (do not have time to read that thread). But I do know that even though the OEM distributors are good, they are not curved nearly as well, performance wise, as they could be. I have also had all sorts of performance issues mostly with points from distributors with lots of play in the shafts..
My personal favorite is probably the '79 distributor with an OEM igniter / points setp. This is basically the same as a FJ60 but has a smaller head so it is not as much of a hassel using is because you don't have to swap side covers on the engine (but not that big a deal). This is mostly my favorite because it is a bullet proof super bomber OEM Toyota setup.. It is electonic, so no points, and basically super reliable..
Issues I found were:
Both the '79 and the FJ60s are heavily smogged. when using on a desmogged engine this also throws the curve off. So I would send the distributor to Jim C. to have it recurved. Unless things have changed Jim C. will recurve any OEM Toyota distributor. I ran them without the recurve and they did pretty well though, regardless... But I do think more umph could have been pulled out of them....
If I remember correctly from dorky LCML daze, OEM vaccuum advance will only go as high as 12 advanced when Jim C (correct me if I am wrong Jim!) will go up to as high as 17 degrees or something like that. So there is more performance and power to be squeezed out of the OEM dizzies, even the late model...
RE the HEI. I actually think this is a fine unit but I **would not** mess with trying to get the right curve and parts etc on a HEI by yourself. I did this route, spent way too much time and money doing it, and then ended up seizing a perfectly good running '79 2F in a FJ40. I would buy a HEI from DUI, that also has the correct performance curve, better and stronger than really any OEM distributor. I do think slightly hotter spark, combined with the correct advance curve, actually does make a difference. But if you don't have the right curve, it is wasted energy. DUI is not perfect though, if you search PBB, one of their distributors took out Box Rocket's (on PBB) engine and required some major rebuilding work. And DUI **did not** entirely stand behind their product and I believe Box Rocket did have to put up some out of pocket money. this is because, even though the Toy and GM engines share common ancestry, **they are not the same engine***.
In order my preferance is probably:
'69 distributor vaccuum advance with octane adjuster aka "a non-USA" distributor with a Pertonix setup.
'79 OEM distributor with Jim C modified advance curve and OEM or Mini Truck ignitor and coil combo.
FJ60 Distributor with Jim C modified advance curve and OEM or Mini Truck ignitor and coil combo.
DUI HEI distirbutor.
But that said honestly all would probably work well IMO and I would be happy with any of the above setups on a 2F.
This has been years since I have messed with all of this stuff so again Jim C / others please correct me if I'm wrong..
Andre
One reason I like a hotter spark..
If you have oiling issues with blowby, worn rings, bad valve seals, etc, it is a lotharder to foul the plugs.
Tha being said, I love the 79 dizzy..
Learning a lot here...thanks to all contributors. I did think that the "big cap" was more waterproof than the '79?
Andre, you know quite a lot about distributors.........for a diesel guy;)
Isn't that like a Catholic Priest doing marriage counseling:D
Ed
BTW, I am running Jason's old junk FJ60 diz.....no wonder he wanted to get rid of it, now that I know his true feelings:grinpimp:
79 is fully electronic and sealed (vented to the cab) just like the big cap is.
Old junk? Works dont it??
:flipoff2:
:flipoff2:
Mace, I was just k-i-d-d-i-n-g:)
Actually, I'll know on Thursday whether it works or not. I sent it to Jim C and he recurved it for my no-smog 2F. I'm getting really stoked about firing it up.
Shakin' like a queer at a Hot Dog stand:D
BTW the whole thing checked out just fine...coil, ignitor and diz.
That makes me happy :D
how much was the recurve from jim c?
