timeing total advance
You only need enough rpm to fully extend the mechanicl advance mechanism (weights). 3000 should be plenty. If possible watch the mark as you rev the engine. Once the mark stops advancing you're there.
You are only checking your mechanical advance by doing this. You can either set 7* at idle OR 21* at full advance. The range is built into the distributor. (I assume it is for a Toyota dizzy. Could be wrong about this.) Vacuum should be disconnected for the test.
The typical dissy advance curve maxes out at 3600RPM. If the advance specs are known for the dissy, then it can be set at idle.
Example: A typical Cruiser dissy will have 20* mech advance and 10* vac advance. Total timing of 36-38* is good for a 1980-earlier 2F. If base timing is set at 8*, then 30* of total advance is brought in, max timing will be 38*.
JIM C to HEI thread! :)
:beer:
The Cruiser dizzy gives 10* vacuum advance at what throttle position and engine load? No disrespect. I just don't understand since vacuum varies widely depending on driving condition. Do you mean 10* at no load? :confused:
