bent lower arm, now what...
PabloVTA
beside La Caja China
Ventura Ca. USA
I bent my Lower control arms, and I need to fix it.
they are Slee's HD solid for a 6" lift. Coated , not previously sleeved or had anything welded onto them.
Apparently hauling a taco truck across the Rubithon can get a little harsh.
Should I remove, heat and smack ?
or Remove, smack, and press?
throw a bottle jack in there and crank? I only have about a 4' steel tube to use as a sleeve, and I'm pretty sure it won't fit over the bushing end. so whatever massaging I do, has to be kind of brutal.
I'm looking for a fix, not a lesson in snarky "search" or a discussion of the Brinell hardness of 1045 steel, or a "hold my beer and watch this" type of hack job...thanks.
:popcorn:
I'd be seeing about a warranty replacement first. If that is a no go then I would use a 20 ton hydraulic press and slowly bend it a little bit past straight, remember there will be spring back and you may want to support it by the arm stock not the bushing ends. I would not pre-heat.
I beat the hell out of my MT .250" wall DOM adjustable rear control arms on Rubicon several times a year for two years now and they remain straight. I have never seen a fabricator use solid round stock on a rock crawler. Not saying an 80 is a rock crawler but sometimes we use them that way.
Well definitely dont ditch the charcuterie!
Could pic up some cheap stock n straight ones, cut and set to desired length and melt some metal. I bent a few stockers but not one since this effort.
An man that food truck is just everywhere these days. Spotted in DV now recently too!?! You hiring? :D
I was being a bit sarcastic about that, but seriously, I would ask Christo about best ideas for straightening those rascals.
i figgerred as much, I think the guys are busy gettin ready for SEMA.
yeah, about that 20 ton press...
I was thinking about the spring back as well. Heating up would just anneal them to a point, right? then rendered useless.
I'm not sure there is a warranty on this type of part. If there was the fine print probably says something about Cadillac Hill and getting fully turtled...
For a temporary fix, I would straighten as best you can with a press. Then, weld angle iron the full length. That will last a few years while you save for new and better ones.
I'll bet Rick has the tooling and we could bust out a few of these. Set up for stock bushings of course.
Pablo, steve actually has a cad file we were discussing for adding angle iron to a "straight" lower link. I was going to do that to mine, just haven't done it yet.
Send him a PM and get that file and/or measurements and go to town. Hopefully Slee will warranty them, but if not, even with a new set i would weld angle on them.
The overall length of the Slee lower should be the same as your old OEM lower, if you still have one laying around to swap in while you attempt to fix or replace the bent unit. (Slee adjusts for pinion angle with the uppers)
Personally I'd just get a replacement coming rather than spending the time to bend back the old one.
Which Slee's do you have, as their design seemed to change over the years. Online now, they look pretty slim. What is the OD of your set?
Slee - Toyota 80 Land Cruiser Series Suspension Arms
I know they are heavy duty stuff, but I would think about doing a cut and sleeve on them.
Heating them up can inadvertently harden the links due to their thickness. If you didn't apply too much heat you'd just end up surface hardening them and not through hardening. That's why I suggested cold pressing. That and you won't ruin the corrosion inhibiting under coating doing it cold. If you don't have a shop press take it to a driveline shop, they will likely have a press and probably won't charge much to bend it back for you.
I'm no expert, but I've heard from a few fabricators that the correct size DOM is actually stronger than solid forged.. either way that sucks.
How bad is the bend? My wife has been running with a slightly bent one for some time without known issues. I was going to flip the arm over and have her run the same trail again to bend it back but she could not remember where she did it.....:lol:
Heating wI'll not harden without quenching. However you will change the molecular structure of the steel. Without knowing carbon content you may actually soften it's rigidity with heat. Better to press cold then reinforce with angle.
True...inadvertently is referring to any number of things that could lead to it getting quenched like putting too much heat into the piece by accident and melting or catching the bushings on fire if they haven't been removed which may lead to getting hosed or dunked if there isn't the proper fire extinguisher nearby. Who knows how much metalurgical experience and knowledge the OP has or tools they have access too. That's why I suggested just bending it cold and calling it a day.
Heating any steel alters it. Best to not mess with our engineered parts.
