Beadlock question
Cheyenne, WY
I have a set of 17" beadlocks that measure out to 8.5" wide. I would like to run a set of 39.5"x13.5" irocks. My question is would i be alright to run a 13.5" tire on an 8.5" rim(i know the standard measurement is 4" wider than your rim). And if i run these tires would that put to much pressure on the beadlock ring and cause me to break bolts if the tires are aired up to normal psi.
I don't think you would have any problems running a 13.5" tire on a 8.5" rim. Many people run 14"+ tires on Hummer beadlocks. Just make sure that you check your bolts on a regular basis.
Ryan.
Thanks guys
I run my IROKs on a 9ish wide rim with no problems :D
