bad idea?
McClaskey said:
Do you guys think it would be a bad idea to spring over my 64?? and why do you guys think so?
With the stock axles, brakes, and all? Pretty bad idea to spend the effort on axles that are difficult to impossible to upgrade for any reasonable amount.
Hi All:
You might want to spring-over the truck in future, once you have all the mechanical and body/chassis issues addressed.
Like has been mentioned, the 1964 axle assemblies are not the best canditate for use with big tires. If you want to do a spring-over swap find theaxle assemblies from at least a 1970 or newer Land Cruiser; up to '75 will still have drum brakes, while '76-84 will have discs on the front axle. A decent budget approach is to buy a '70-75 drum brake frontend and the frontend from a 1979-85 Toyota 4wd mini-truck, then swap the mini-truck outter knuckles, disc brakes, and Birfield joints onto the Land Cruiser frotnend. Search theMUD archives for more info on this disc brake conversion.
Regards,
Alan
Seattle
I just did SOA my 65. :)
I also converted to axles out of a 69 FJ40. In the process of converting to the 69 axles, I did the toy pick up knuckle/disk brake conversion on the front axle and converted to disk brakes on the rear, with a total rebuild on both axles. Oh and I put Ausie Lockers in the front and rear.
I also converted to high steer at the same time.
The brake system is all brand new with a new 75 corvette master cylinder and new break lines.
I guess what I am saying is it can be done, but to make it worth doing on an older cruiser it can be a lot of upgrade work.
Before I did all this I had 4” Skyjacker lift springs under the old axles and they worked great.
Yes, if you're trying to keep it original.
Your truck, do what you will, but you might be better served with a later vehicle for a SOA conversion - better axles and transfer case, better parts availability for everything else, and more shared experience in the community.
If I were you, I'd restore the '64 (or at least avoid hacking it up), and find a later truck (78 to 82) to convert to SUA.
HTH
Kirk
I think there are 2 ways you can go... keep it stock and wheel it or just do the SOA and upgrade when things break. The ball and claw and 3 speed case isn't the best but it's still cruiser. Before you know it you'll want to upgrade the axles, gearing etc. and most of these parts would be next to worthless. Still at this point it'd be a cheap wheeler for you. Most folks take the early cruisers and scrap the drivetrain if it's cheap enough or just go resto route.
McClaskey said:
Well im only 17 so i really dont have many options. I dont think i can afford a soa
My . 02 is to get it running and in good comfortable condition. Then try out the wayno especial copied below. You'll have a few $ for shocks and tires. Learn to wheel with 33's have fun and upgrade later on.
From the LCML..
Here's the deal: Rancho add-a-leafs P/N RS60612 contain two add-a-leaves, 3/8
center pins and 5/16 center pins, they are $60 each and you need two sets. Use
the smaller pins. Jack up the frame and unbolt the u-bolts. Remove the existing
center pins and then remove the bottom two stock leaves, the two shortest ones.
Put the add-a-leaves on and clamp with c-clamps, then put in the center pins,
replace the u-bolts and away you go. Notice YOU DON'T EVEN HAVE TO REMOVE THE
SHACKLES OR SPRING PINS!!!! Yes, I'm shouting because these are what makes
suspension work so much work. You will want shocks a little longer for full
droop, but the bottom line is that this inexpensive lift will retain good
steering geometery, ride is as soft as stock, run 33s with no rubbing and great
articulation of road. Here's a photo of mine twisted up:
http://risingsun4x4club.org/forum/uploads/Rzeppa/B46_twisted.jpg
HTH and happy cruisin'!
Jeff Zepp
Kittredge CO USA
1971 & 1976 FJ40s, 1978 FJ45
Rising Sun 4WD Club/TLCA #4063
http://Rzeppa.org
McClaskey said:
Well what about a 4inch lift ??? Would the old axles have problems with a 4 inch lift and 35's?
I ran my 65 for a year with 4" skyjackers and 35" bfgs.
I wanted lockers so I upgraded the axles and went SOA at that time.
In my opinion the 4" lift and 35" bfgs worked fine. you will need to cut the rear fenders and you will probably need longer break lines.
I personally would stay away from add-a-leafs. My 65 had them when I bought it and you might as well of welded the axles to the frame.
You will want power steering with 35" tires.
If you don't have the money to do a lot of mods, you should look at putting taller skinny tires on. I think it improves the looks quite a bit over stock and you won't need to modify your 64 to do it. if you search on here you will find some pictures of cruisers on tall skinny tires. Land pimp has a couple set up that way.
Any rancho dealer or heep place I would guess. I wouldn't have recommended this approach without seeing jeffs rig in action and knowing how fickel he is about the ride too. It's less like add a leafs because you remove 2 stock leafs and add a fresh leaf. I think he prefers stock shackles but maybe with some extended shackles you might be able to squeeze 35's... and yeah like stratton says you'll want PS..
I have nothing against SOA ( I actually have one) nor 4" lift...I only brought this app up due to your $
Good luck McClaskey, Your 64 is almost identical to mine :)
Got 60612's and 4" kits in stock. You can call me at the shop to follow up on these when you're ready.;)
BTW, as far as my opinion goes, I'm with wesintl on getting the truck running for now with less $$ on stuff like suspension until you've got stuff like steering and brake issues up to snuff. It's good to make long-term plans, and to ask us for opinions so you can come up with a long term strategy, but those plans are worthless if you crash your truck because you can't control it.
Keep in mind that as you go bigger on the tires, it's going to take more HP and torque to run them without a corresponding change in the gearing. In my case I have a V-8. How strong is your engine?
And, it's going to take a lot of lift to clear 35" tires. Here are some photos of a 71 FJ40 with 33" tires with only 2.5" lift springs and stock shackles.
Notice that the rear wheelwell opening is very tight. It doesn't take much of a lean or spring compression to cause rubbing. The lift is not enough. I have since added longer shackles, 3" over stock, which give 1.5" at the axle. It's adequate, but is not a long term solution. What's really needed are 4" lift springs with possibly moderately longer shackles. These are 33x12.50x15 tires. If the tires were skinnier, the rear might tuck under the wheelwell opening. These tires as they are really need either a cut wheelwell, which I do not want to do, or a much higher lift, which is possible with a higher lift spring set, or a spring over axle conversion, which I'm not keen on, but I have not fully researched it out yet.
The bottom line is this. I think on your budget, you *may* be biting off more than you can chew with 35" tires. Even 12.5" wide 33" tires are asking a lot of a stock or mildly modified FJ40 because of clearance issues. You can clearly see that from the above photos.
If you go to this link http://store.yahoo.com/coolfj40/liftkitfj401.html you'll see a red FJ40 with a 4" lift, and further down a mustard FJ40 with a 2.5" lift, both running 33x10.50x15" tires. Note how the skinnier tires have less problems with the rear wheelwells.
It all boils down to what you can do on your budget that will work.
