The yellow black wire is your ign hot out of the ign switch. The yellow black should go from your ign switch, then to your coil, and from the coil it should go to the distributor. Seeing as we still havent found the circut that is causing your draw try this. Connect the test light in series with the batterie like you already have done before. 2) cut the yellow black wire coming from your ign switch (you can always reconnect it)l. Ill bet you you wont have the draw after you cut that wire. This would be great because we would now know what circut is causing the draw...ill be waiting
