all right so removing the key only worked 1 time...i searched and followed all the steps...remove - battery cable..check for drain...and yes there is some...took alternater connectors off...1 frayed...replaced it ..hooked back up still drain....took each fuse out 1 at a time...no change...took all wires off starter..clean hooked back up..still a drain...what am i missing?.....what step have i missed...removing the fuses should have stopped the drain or at least help me figure out what circuit...but nothing...help please..where else should i be searching?
With all the fuses out and you still have a drain the choices should be minimal. If nothing else start disconnecting stuff till your drain goes away. Is the wiring factory with nothing added? How big of a drain are you looking for?? How are you checking?
the wiring is quasi factory..sorry i should have mentioned it has a chevy 283 in it...the main harness is pretty intact with a couple of add ons...i was able to use factory diagram to figure out all lighting and accessories...i added a stereo and a cb and thats about it...what items should i disconnect?.....thanks for your help
What scale is it set on? How do you have the meter hooked up? You need to set it to read amps and disconnect the + battery cable and hook one lead to the cable and the other lead to the + battery post.
After you removed the fuses you next step should of been to check the relays.
A easy way to find your drain is to hook a test light up from your battery terminal to you your battery cable(Posotive or Negitive, it doesnt matter). If the amperage draw is high enough(above 4 amps) the test light will light up. On some vehicles there is a computer controlled relay that may turn on, causing the light to turn on, to eliminate this, temporarily connect a jumper wire between the battery terminal and the battery cable while leaving the test light in place. After removing the jumper wire, the test light might go out. If the test light does not go out , your amp draw is over 4 amps. If the test light goes out the amp draw is less than 4 amps. If you have a draw of over 4 amps its probably your alternator diode, or ignition switch.
If the draw is under 4amps use ayour ammeter just as you did the test light, do not disconnect the test light untill you have hooked up the ammeter, this will keep the relay(if theres one used) off.
When you disconnected your alt. did you still have the drain?
After you disconnected the fuses and didnt find the drain did you try disconnecting your relays, one at a time just as you did the fuses...
What scale is it set on? How do you have the meter hooked up? You need to set it to read amps and disconnect the + battery cable and hook one lead to the cable and the other lead to the + battery post.[/QUOTE
He can get away with that on very low current draw. I would not try turning items on, like the headlights, to see how much current they draw without knowing what, if any, internal shunt the meter has and it's current carrying capacity.
all righty...back after the parasitic draw on the battery...this time i hooked up a test light...removed positive battery cable...and put light in line...light comes on...disconnect all wires at the alternator...light still on...remove one fuse at a time...the light remains on with each removed fuse...removed ignition from the dash and diconnected all wires going to the switch...light still on....disconnected a few misc connections under the hood...light still on...unplugged wires from black box on drivers side firewall..regulator?...light still on...where do i go from here?...chevy v8 conversion by po...for those that don't already know that...all help is greatly appreciated....this is driving me almost as crazy as the light issues from earlier
Without a schemitic, I would get a testlight and find a good ground and start poking around anything that has a switch or power coming to it or anything that has a current going through some kind of resistor or coil( relay, starter, voltage reg. etc.) that completes the circuit. Does this thing have an ignitor? This is odd....at this point I would even consider disconnecting the starter entirely. Good Luck.
how many wires should i have coming and or going to the voltage regulator?...which wire to the starter should be removed?...i have a strange wiring issue near the regulator....only 2 wires to it...they plug into the terminal nearest to the outside of the truck...the other two terminals are empty...the one closest to the engine light up the test light with the battery cable on...now i am really confused
I just pulled the factory manual and was looking at the wire schematic. From the battery, it goes directly to the starter, ignition sw. and instrument custer via a fuseible link.
That being said, you have already disconnected the ignition connector. So that still lives the starter & instrument cluster. Start disconnecting each until it goes out. And go ahead and live the ignition connector disconnected.
As far as the voltage reg. is concern, disconnecting the engine fuse should take it out of the circuit which I believe you have already done. It should be located on the firewall.
All righty..now your going to make we work...I love a challenge...So I'm assuming that you disconnected all Relays also (one at a time while the test light was inline), as I previously posted.
At this point I would unravel a section of the wiring harness and using a test light, probe each wire one by one, you will eventually hit the one that's causing your draw, its a painstaking way to do it, and will take some time.
Give me a couple hours and Ill get back to you...meanwhile im going to do some reading and testing of my own
please clarify relay...i know the horn has a relay...what others should i be looking for?...i will try removing all the fuses at one and see what happens..forest i will start checking wires....i just have a feeling its got to do with the old guages that are no longer in use....oil sending wire..yellow black stripe was hot when i tested it with the battery cables on and the ingnition off and key removed...that seems odd to me
