Back To Electrical Issues...help....Please
put it quasi back together...now i aint got any turn signals...ih8electrical!!!...done for the day...the heat subsides and the mosquitos show up in force!:eek: .....any and all input still welcome and thanks all that have posted...i am sure i will get it figured out eventually...
osagecruiser
When checking current you have to break the circuit and place the meter in the middle of it. So to answer your ampmeter question is: Yes reconnecting the ends is correct. The fuseable link is located past the battery. Sorry for not making myself clear on post 17.
osagecruiser said:
i just hooked the wires back to the starter..batery cable plus one at a time the wires that were originally hooked to the same post as the battery....first wire...test light on...removed it and put the next one on...second wire no test light..yipeeee...now i have to trace this bad boy and see where it goes...the wires at the starter are not color coded so i will figure out where it goes...hey pin what about the ampmeter question in my last post?.....and where exactly should the fusible link be located and what does it look like...i will get this electrical system squared away yet!...thanks
osagecruiser
It sounds like your PO bypassed the ignition switch when he wired your truck to the IG terminal of the VR. Now, I am not certain, but I wonder what you have, here.
You mentioned earlier that you have only two wires to the VR. One of them is this one, which goes to the battery for all intents and purposes.
Where does the other wire from the VR go? Is it a ground? Or does it go to the alternator?
If it does not go to the alternator, then it is likely that you have an internally regulated alternator, meaning you don't need an external voltage regulator to limit the voltage coming out of the alternator.
Again, in that case, you don't need the voltage regulator or the wires to it, and it's possible that that is at least one drain, since you said the drain went away when you disconnected this wire from the starter post.
Guess we need to get that straight, first.
osagecruiser
I keep forgetting that earlier cruisers get the chassis power off the starter motor lug and not from the battery post. They don't have a fusible link either. The chassis power is a large white wire. NO problem bypassing the amp meter, although I would prefer solder and shrink wrap over a wire nut.
Since you at it at and it does not have a fusible link, I would consider installing one.:). Also install a ground cable from the chassis to the starter if don't have one. :)
idave
no wire to the alternator....the wire from the vr is white with black stripe...i assume a ground but i have not followed to its end...that on the agenda for this evening....the wiring seems to go...battery..starter...fuse block/ignition...alternator...somewhere something is not getting shut off with the key...thanks for your help
osagecruiser
Then if what you've described is correct, you can remove the VR from the system. It isn't doing anything exept producing a current draw.
I'll suggest you put the big wire back on the battery post. See if the draw is gone ( it should be, you said it was before ). Add back fuses ONE at a time. See which circuit produces the other draw you apparently found.
By the way, in the STOCK configuration, your wire would go from the battery to the big starter post to the ammeter (+) post, off the ammeter (-) post where it splits off one to the alternator, goes on a bit, then splits another off to the AM (ammeter) terminal on the ignition switch, then goes on to the (obviously) non-switched battery side of the fuse box. To which you've got headlights horn and brake lights attached.
thanks i dave and fjwagon...i hope to get a chance to work on it tomorrow...and yes i am adding a fusible link and chassis ground while i am at it....i feel real close to having the problem solved and some more of the po wiring cleaned up...stay tuned for further updates...thanks again guys
osagecruiser
