Average engine temperatures
musthave
All maps, one app!
Supporting Vendor
Florida / Colorado
It looks like I'm seeing my "average" engine temperature sit at about 203 for the most part. Colder weather, maybe it cools off a bit, warmer, maybe it is hotter, but it pretty much is around 203.
Would that be considered high?
What are other people seeing?
How much does the ARB front bumper affect the airflow, and does it result in a hotter engine temp?
Mine is around the high 180's to mid 190's. I might hit 200 going up a hill. I also have a stock bumper and I installed a non modified blue hub fan clutch also.
I have a stock LX450 with the stock fan assembly and run about 186* pretty consistantly.
Pretty steady at 194 per Ultragauge, with no AC. I hit 200-205 on long grades. Around town this summer with AC on high in 95+ temps I was seeing 198-200 on average. I noticed no difference in temps after installing my ARB bumper.
Pretty much spot on with teddys specs above via scan guage
I'm seeing around the low to mid 180s for the most part. Some hotter days I will get up to the low 190s or a little higher through bunches of steep switchbacks and hills. Once or twice when wheeling in the middle of summer in New Jersey I got it up to 200-205 but no problems.
This is with a Koso Digital temp gauge, ARB winch bumper, Two lightforce 240 blitz mounted on the ARB. No mods to fan assembly or anything like that.
Its pretty hot/humid down here and I saw steady 190 last couple months(summer). Since its a little cooler now Im seeing 185-190 during the day. 180-185 at night. Just w/blue clutch fan.
Im at 175-183 on average. When it got to 100 degrees over the summer and i ran up a good hill it peaked at 193. Im running standard toyota coolant with redline water wetter, good quality phh lines, and a 2 year old radiator and radiator lines. And im not 100% sure if the PO did the blue fan clutch but he may have.
185-205 with a/c in 95+ weather with a mix of rusty water and miscellaneous coolants in a 257k mile stock radiator. (Currently collecting parts for a coolant overhaul). Data collected from my Edge CTS
188-190'F with 85-95' F ambient air temps (no A/C, flat terrain, normally aspirated, stock radiator, clean cooling system, 50:50 Toyota Red and distilled water, relatively new water pump and Tstat, unmodified black hub fan clutch).
Wow, I feel like I'm running a little hot all of a sudden. I'll have to watch temperatures on my way home tonight.
I doubt it. I think I'm running to cool if accurate. While +200 may be on the warm side, it is now where out of spec from what I read here over the years.
At 100 degrees in traffic I hit 198. Now at 80 degrees I run 182-186 typically per scanguage
Upgraded 3 core rad / blue fan w 15k fluid/ new pump and belts hoses plus 3fe fan all helped
With my hella 4000s blocking the grille on the slee I was roughly 5-7 degrees hotter so I swapped out for a smaller footprint w 1000's
My 92 for reference seemed to run at least 10-15 degrees hotter per scanguage with just a rad and 10k clutch & hoses
