Average engine temperatures
Isn’t the placement of these cheap looking led bars right in front of the front grill area a pretty stupid idea or is the owner onto something rather clever?
Its the stock fan clutch which seems to do alright, but I have a 12 inch electric fan on one side of the radiator and another on the transmission cooler.
As I said earlier the return line to the engine feels cool to the touch, so I am getting ample cooling capacity, just was wondering about my 'new' vatozone thermostat.
Anyway, I've ordered a OEM thermostat and the Koso gauge.
Yep, I would guess the non OEM t-stat. To be sure you can perform an easy test for the fan clutch when your engine if fully hot like your photo shows. Shut off fully hot engine and pop your hood. Grab the fan clutch and try to spin it as hard as possible by hand. If it rotates more than a couple fins, basically if it spins at all, its not a tight clutch.
on a 7 mile trip on the street, stop and go, in the Arizona summer it will get up to 190~195. 190 while moving. 198 ~203 in hot sand.
entire cooling system is new and a non modded blue hub and 20k. I'm seeing these guys with 180+ degree temps and want the same but where I live is probably impossible.
I've never heard of anyone getting better temps than that in our desert. The OEM thermostat doesn't even open until 180 degrees. Running cooler would not be beneficial.
This is my temps earlier this month crossing Death Valley. the 183f is the reading from the koso sensor which is on the "cooled" side of the radiator. The 46.2c (115f) is the outside temp. This was on flat ground at around 60MPH with no A/C on. With A/C it would rise to 192f, My temps only really started to rise if i hit an incline and didn't keep the Revs above 2500. I am still on stock gears on 315's so that mis-gearing had a big influence on engine temps during climbs.
throttle wide open from Georgetown (8,530 ft) 13 miles to the Eisenhower Tunnel (11,015 ft), that's a gain of 2,485 ft over 13 miles. The Pict below was taken on the climb about 2 miles from the tunnel, I was shocked to see the engine actually cool down below 180 degrees when the fan clutch engaged.
This speed hut gauge is certified calibrated and is in the block drain location. Also have a Koso on the outflow of the engine and it was registering 180 degrees at this point. Right after I snapped this photo the fan clutch disengaged, temps rose back up to about 190-195 and the fan gradually back on.
Ambient temp was in the mid 80's, speed 65mph, stock gears, 35's, 7,000lb per CAT scale. 30,000 miles on the 4.6 rebuild. New cap, new belts, 80/20 coolant mix, no ac condenser, Blue clutch with 20k oil, advanced 1mm. Clutch seems to engage starting at 182* then fully locked by 195*, it cools to 178*. If my engine is running above 195* I know something isn't right, see my other post regarding this.
img_0202-jpg.1741164
