GOT MINE!In case your would like a tank for YOUR 200.....
Long Range Automotive Extended Range Fuel Tanks
Thanks , Mark!! Got any photos? @orangefj45 is looking for some snaps-Gotta say...
24g tank is just plain awesome.
Highly recommend to anyone with their spare already on a swingout.
No problem fitting it with Slee rear bumper in place, either.
Testimonial regarding clearance with the 24 gallon unit:
I spent three and a half weeks beating up my armor between Moab, Telluride, and Breckenridge...and despite tons of hard hits to EVERYTHING underneath (skids, rear diff, shock mounts/guards, bent rear control arm, the entire surface of the bottom of rear bumper, sliders and more...)
...Not a single, solitary touch to my up-armored 24 gal. LRA! This thing is just so nicely tucked.
Also... with my heavy rig, I can’t even tell ya how nice it is to have literally double fuel capacity with no hassle of rotopax or Jerry can time, spills, stink, crud and garners PITA mess.
Lowest possible center of gravity...fast fill/transfer time...boiling gas remedied...peace of mind...
Georg at Valley Hybrids is awesome, and even accommodated a faster pump I had installed.
Highly...highly recommended!
PS. Price-wise...
You can avoid seriously expensive Jerry cans and even more expensive RotiPax cans, mounts, locks that can add up to easily over $700 (Rotopax accessories are pricey!) just to end up with mess, higher COG, storage issues and time in the field eaten up...when you could apply those costs to an LRA install.
If you’re on the fence...I’d jump on the discount. Fantastic mod you won’t regret.
Markuson
PS. Price-wise...
Markuson
Thank you sir!I'll echo all of Marks comments except I haven't been off-road yet with it set up. I am amazed how nicely tucked it is. No worries at all about hitting it. Programmable system as well. I'm on full manual, but had to change to that, and it was a breeze. Lots of options to consider.
Ward, I'll snap a few tomorrow and post them here.
Took a few shots today. Fact is, there isn't much to shoot which is exactly why I'm liking the 24g so much. You just don't know it's there until you hit the switch and start transferring the fuel.
This shot I tried to get as even as I could so you can get a clear picture of where it hangs lower than the bumper. I have the RLC bumper which is very high profile compared to most others. You can see just behind the tires where the tank is.
Guys at @ACC Toyota did a great job with the install so any of you Atlanta folks looking for this mod, they are your go-to place.
Straight on shot from the rear.
From the other side
And one shoot up from the rear.
The pump seems to work just fine for me. Don’t really see the need.Is there another fuel pump that can be used other than the supplied one?
I've read a different pump can be used that pumps faster.
It should only rattle terribly when the tank is empty and there is no fuel for it to pump.I ask only because the pump I have makes a lot of noise. It rattles terribly.
Rattles?! I would say mine knocks when not flowing fuel when empty but that’s it. Not rattle. Mounting issue? Pics?I ask only because the pump I have makes a lot of noise. It rattles terribly.
