AT WITS END
1991 cruiser has no spark....for three months
replaced everything that makes a spark
new igniter
new coil
new dizzy
new computer
new wire, cap, rotor, plugs
new fuses
new relay
new ignition switch
checked all wires over and over and over again
error code is 14
"no IGF signal to ECU"
toyota said it would cost thousands to figure out
thinking about junking this vehicle
what voltage is the battery at? You said you shot the signal wires from the coil to the ECU?
In 1993 had a 91 80-series with 60K on the clock, that died, no spark. First time was way in the back country at elephant hill in canyonlands. After an hour it started for no explained reason. I got it home and it died twice more before I could get it to the dealer. They had it for two weeks. Same thing. they checked out the dizzy, ignitor etc and finally replaced the ECU, took all my money, and sent me home broke. It died before I got it home. I towed it back and they put my old ECU back in and gave me a refund and told me to NEVER COME BACK. happened dozens more times... intermittent no spark and then would start up the next day or so. A few weeks later it died in a busy intersection in downtown Salt Lake. In desparation, I reached up under where the harness clips in to the ECU and wiggled it around vigorously. It started. Twice more in the next week, same routine. It Never happened again. I Drove the truck to 450K with no more problems, then sold it to a friend who drove it for years more with no repeats. Check your wiring harness and all connectors rather than the components.
It wont cost thousands. It could a short in the harness somewhere. Do you have another harness you could slave in?
Fusible link? Charged battery?
I would follow the wire:
Is there spark/voltage at plugs?
If no then is there voltage at dizzy?
If no then voltage at ignitor?
If no then is there voltage from the wires to the ignitor?
Just my 2 pennies
Oh and don't use trademarked "wits end" without permission. ;)
new igniter
new coil
new dizzy
new computer
new fuses
new relay
new ignition switch
error code is 14
What caused all of this in the first place? You just went out one morning and it didn't start?
Have you tried disconnecting the battery for a little bit and then reconnecting and trying to start?
My vote is for grounds as well. I had a similar issue with my 92 3FE. My battery was new but wasn't charging. Alternator was reading "bad". And I would get the intermittent no start (crank but no spark). Went to replace the alternator. The main ground from the battery was barely hanging on. Tightened it down. Didn't replace the alternator. That was 5-6 years ago...
I'm not saying it's the main ground for sure but I would go through and check them all. And check your wiring harness as well. It sounds like an electrical gremlin to me. The 3FE is a simple motor. You've replaced all of the components that make it spark and it's still not sparking so it would make sense that it is wiring/grounds somewhere.
Well, if you decide to part with her send me a pm. I've had this before on other cars and it's been dirty/corroded connections - though sometimes it's a starter/transmission issue.
Start with what you know and work from there. YouTube. You'll figure it you. It's not a woman, though they can be temperamental and hot blooded, right @scottryana @NLXTACY :flipoff2:
