I have a ARB bullbar with ASFIR front skid and @TRAIL TAILOR diff drop. Here's what it looks like:
Goal. Since it works with the TT drop diff. Thanks for sharing.
Anyone mount the front skid to a Slee Bumper and Diff Drop yet? I think I'll either be doing some bending or thicker spacers...Super fast delivery from Asfir and well packaged
do you remember if you elongated them towards the rear or the front of the car?Mine is mounted to a slee diff drop. The holes needed to be elongated in the rear to fit but otherwise went in easy.
thanks i thought you just meant the rear holes needed to be elongated not necessarily towards the rear. I just wanted to get a head start on elongating before getting under the truckCheck the post immediately above your question
Elongated towards the rear
I’ve drilled out a few. Center punch old stud, and use a new bit to insure best cutting. Otherwise, surprisingly easy.Quick question. The original Front skid plate Plate bolts are broken off on my rig.
How difficult is it to drill out. Any more difficult than drilling out anything else?
Honestly, it’s a rolling advertisement for my fathers Cerakote business, he’s a factory certified applicator. We wanted to see and to show just how durable it is, as well as using my vehicle as a test rig for many different applications. My rims are done as well.They look great. I'm curious why you may have gone with cerakote for a part that would be so likely to take hits and scratches.
I’m in Valdosta. Thanks, I really appreciate it. Where are you located in GA?Where in GA are you? That's really cool!
About 2-3 months now. You are correct, it does have to be blasted and redone, same as powder coat as I recall. I understand why this would be a turn off to some, but so far it’s been durable. But, like a said in the previous post, it’s a rolling advertisement and durability test for myself and my father. I’ll be coating other parts along the way. My passenger side exhaust manifold is coated as well. (Haven’t installed the drivers side yet as it’s not leaking)Curious, how long have you had your wheels done in Cerakote? I had a gun in it and as I recall it couldn't be repaired - ie it had to blasted off and redone. Is that accurate? I really like the looks of it on the skids and wheels.
I would reconsider using socket head cap screws, a hex head is lower profile and is much easier to remove when damaged than a socket head screw.Finally got mine Cerakoted and mounted. I need a longer center bolt, and I ended up breaking an extractor off in the passenger front bolt.... but it’s mounted for now until I can drill out the hardened extractor and rest of the bolt.
