Arizona Classifieds / For Sale / Wanted
In search of:
For ‘82 FJ 45. ( any FJ40 units should work)
Radiator mounting bracket ( U- shape hold radiator to cross member)
Front radiator cover and hinge ( holds headlights and secured to to cross member)
Thanks!
Scott
I have a set of 100 series solar screen's, all rear windiws, that I haven't been using.
Asking $200 local CSC price, these come in a carry bag, also have some custom front driver and pass side window covers (a different brand). The covers are all custom cut to fit the windows, mount with suction cups, and comes with a few spare cups in case one gets damaged. They help reduce condensation, provide privacy, and are insulating.
  • SolarScreens Touring set (5 total pieces)
    • Second row Drivers and Pass side
    • Third row Drivers and Pass side
    • Rear hatch
  • HeatShield custom set (2 total pieces)
    • Front row Drivers and Pass side
SolarScreen, one of the rear covers:
Front two window covers are custom by HeatShield:
I've got a Warn 8274 about midway through a restoration... It's a 24V model that I've been toying with converting to 12V. Picture below are the main parts sandblasted... steel parts have been primed. I have the solenoids, motor, and all internals. I do not have a controller or solenoid cover.
Asking $300 OBO. If it doesn't sell I'll invest time/money and convert it to 12V and restore it. I just don't need the project right now.
Just a bump... I’ve still got this hanging around...
Used parts that need to disappear from my house (Tempe), either to somebody that can use them or I'll put them out of their misery at the scrapyard/dump. PM me for photos if wanted, and all prices are toss-up OBO; FREE = would not turn down a Coors Banquet, if offered (I'm a cheap date):
From 2000 UZJ100 with 200k miles
- OEM front and rear bumper covers in medium gray metallic (UCA76 paint code). Front has dent on passenger side and 2 broken lower mounting tabs, but all upper tabs are fine and has fog lights. Rear has 1 dent in each corner, but all mounting tabs and both mudflaps are intact (I also have a spare mudflap). FREE
- OEM running boards in medium gray metallic. Both are in good shape. $100
- OEM Front upper driver side control arm. Needs new ball joint and bushings. FREE
- OEM rear lower trailing arms. Bushings are surprisingly OK and not torn, but suggest wirewheel + repaint (they're ugly). $50
- OEM Quarter panel-mounted passenger side taillight. Has ~4-in long surface stress crack, but not all the way through and so does not leak any water into housing. FREE
- OEM front brake rotors with ~25k miles. Still well within specs and not warped, but do have very minor grooving, so probably should be turned/machined before use. FREE
From various 3rd Gen 4Runners (1996-2002) with 180-220k miles:
- OEM front "stubby" bumper (NOT "fatlip" bumper). Excellent condition, no dents or scratches, and includes OEM mounting brackets, turn signals, and fog lights. $100
- OEM front clamshell differential w/4.10 gearing. $100
- OEM front brake calipers for 16" wheels. Need new piston seals. $50
- OEM rear lower trailing arms. Bushings are shot, but are easily replaceable (unlike 100 series arms). $30
- OEM full set of front and rear leather seats w/ all mounting brackets. Rear seats in good shape, no rips/tears. Passenger front seat needs cleaned, but no rips/tears (EDIT: mice destroyed PS seat bottom😔). Driver front seat bottom has cracking and a couple of tears. $50
- OEM carpeted full cargo area mat + rear seat backing. Needs cleaned, but no rips or tears. $50
From 1990 2nd Gen 4runner with 120k miles:
- OEM rear coil springs. FREE
- OEM full set of front and rear leather seats w/ all mounting brackets. Rear seats in good shape, no rips/tears. Passenger front seat needs cleaned, but no rips/tears. Driver front seat has cracking and one ~6-in long tear. $100
PM'd for bumpers
I can post up some pictures if you are interested, but here is an example/placeholder for now:
PM sent
- OEM front and rear bumper covers in medium gray metallic (UCA76 paint code). Front has dent on passenger side and 2 broken lower mounting tabs, but all upper tabs are fine and has fog lights. Rear has 1 dent in each corner, but all mounting tabs and both mudflaps are intact (I also have a spare mudflap). FREE *PENDING to knewstance*
- OEM Quarter panel-mounted passenger side taillight. Has ~4-in long surface stress crack, but not all the way through and so does not leak any water into housing. FREE *SOLD*
- OEM front brake rotors with ~25k miles. Still well within specs and not warped, but do have very minor grooving, so probably should be turned/machined before use. FREE *SOLD*
- OEM front "stubby" bumper (NOT "fatlip" bumper). Excellent condition, no dents or scratches, and includes OEM mounting brackets, turn signals, and fog lights. $100 *PENDING SALE*
- OEM full set of front and rear leather seats w/ all mounting brackets. Rear seats in good shape, no rips/tears. Passenger front seat needs cleaned, but no rips/tears (EDIT: mice destroyed PS seat bottom😔). Driver front seat bottom has cracking and a couple of tears. $50 *PENDING SALE*
- OEM carpeted full cargo area mat + rear seat backing. Needs cleaned, but no rips or tears. $50 *PENDING SALE*
UPDATED
For sale
1996 Land Cruiser engine transmission and transfer case with 179k miles. Engine smokes a little on startup and does use some oil in-between changes. Transmission has a shift kit installed and works fine. Transfer case has no issues. I have used synthetic oil in all three since I purchased the Land Cruiser in 2012. Currently still in vehicle if you would like to see or hear it run/drive. I will pull them out of the vehicle in about two weeks (12/20/19), possible sooner if needed. Would like to sell as one unit but may consider separating, 3000 OBO for all. Cell 253-6eight6-85zero3 located in Mesa.
Nice gray center console for sale. Asking $50 for it.
